Installed C & L/Predator
Guys,
I just installed the Predtor 91 Octane Tune into my Stang and now I am getting a CEL and I ran a diagnostic and it said "bank 1 lean and bank 2 lean".
Where did I go wrong? PLease help!
What did it say exactley? There is: Bank 1 sensor 1, Bank 1 sensor 2, Bank 2 sensor 1, and Bank 2 sensor 2...Bank 1 and 2 is right or left side and sensor 1 is your manifold O2 sensor(important one) and sensor 2 is the cat O2 sensor.
Did you buy the C&L and the Predator as a package? Did you install the C&L tune or just the regular predator 91 octane tune? The C&L tune is downloadable from diablosport if you don't have it already on your predator.
Originally posted by Rebel73@September 9, 2005, 8:05 PM
it said
P0171 System too Lean (Bank 1)
P0174 System too Lean (Bank 2)
P1000 OBD Systems Readiness Test not Complete
If by chance I did install the wrong tune, should I restore the factory backup and do it again?
I had the same problem with my Steeda CAI kit. You need an updated C&L tune. The tune you have is for a 85mm kit. You need the tune for the 90mm kit which I don't know if C&L has yet. I know Steeda updated theirs already. You'll have to probably email C&L and ask them for an updated tune and see what they say.
C&L has a 90mm out now? I thought it was said here the 90mm would be coming out next month. Anyways, if you did download the C&L tune from here, then you have the C&L tune. To install it, select the custom tune option rather than the performance tune option during installing. Select the tune listed there (I don't exactly how many will be here, I don't have a C&L) that you want. If you have already done this, then you have the correct tune installed. Wish I could help more
I think I figured it out! I had installed the "Performance Tune" rather than the "C & L MAF Tune", which explains why it was running lean. Thank you so much guys for all your help. That's why I love this forum so much. NOw to get out there and try her out!
9/10/15 12:44 PM
