Installed C&L CAI Today, Couple of Questions
Old Aug 17, 2008 | 08:53 PM
Bigjht's Avatar
Got everything put on and installed my Brenspeed Tune today. All I can say is I love it. One question I have though is it normal for the filter shroud to rest on the anti-lock brake lines? I know it says to attach the zip tie to the lines to secure the shroud but I don't like it resting there. Anybody put padding between the 2? I put the shroud in without the kit and I don't see any other way of it resting in there. Otherwise, I'm very impressed with the two.
Old Aug 18, 2008 | 10:36 AM
tdbrown75's Avatar
I lined the edge of the shroud as well as the hole which the MAF tube passes though with some rubber trim I got at the local auto parts store. It’s self adhesive and has not budged at all. I feel much better knowing the MAF tube and lines will not be rubbed by the hard plastic shield. I think the stuff costs maybe 5 dollars, and was made for the edge of the door. Comes in two long trimable strips. Hope this helps!
Tim
Old Aug 18, 2008 | 05:19 PM
Bigjht's Avatar
Tim
That sounds exactly like what I was thinking. Thanks for the advice. Is your resting against the brake lines as well?
Old Aug 18, 2008 | 06:59 PM
tdbrown75's Avatar
Yes it is, but it does not seem to be causing any problems whatsoever.
Tim
Old Aug 22, 2008 | 08:04 PM
mot250's Avatar
Tim
I've had mine on this way for going on two years, no problems.
Old Aug 23, 2008 | 12:31 AM
Wardog 07's Avatar
Had my C&L on for 3 years now. Only issue I have is that the plastic has cracked around the bolt hole (where the plastic is bolted to the inner fender well) - (far right of picture). Noticed it the other day, not sure how long it has been that way.
Attached Thumbnails Installed C&L CAI Today, Couple of Questions-clintake.jpg
Jim74656
May 1, 2023 02:15 AM
Ecoboost
Jul 25, 2015 06:32 PM
valanahara
Jul 22, 2015 05:13 PM
