Installed BMR LCAs
Old Jan 21, 2006 | 07:05 PM
dustindu4's Avatar
9 is not my lucky number.
It's real easy. Here's a step by step. These are the dual poly bushing lower control arms from BMR.
Jack up the back of your car by the pumpkin, don't let the jack touch the cover so it doesn't get damaged and spill out your fluids. Place jack stands on the axles on each side, equally spaced out.
Remove both wheels
Disconnect the e-brake cable bracket.
[attachmentid=43381]
Remove the clip off the ebrake cable and disconnect the he cable (refer to the pdf, my picture didn't come out)
Using an 18mm socket wrench, disconnect the front of the LCA arm, then disconnect the back.
[attachmentid=43382]
ONLY DO ONE ARM AT A TIME. IF YOU DISCONNECT BOTH AT THE SAME TIME YOUR AXLE WILL SHIFT WAY OUT OF POSITION!!!!
Now would be a good time to put thick lithium grease inside the steel bushings on the BMR arms. Don't use regular grease because it will dry up the poly bushings over time. This might prevent squeeking down the road. I actually bought grease to do this and I forgot to do it, but they don't squeak so whatever.
On the BMR arm ends there's a narrow and a wide end. The narrow end goes in the front of the car. Now this end didn't fit really well in my brackets. I used a screwdriver through the bolt holes and bend the brackets open a little bit. Then I used a rubber mallet to bang it into position. Stick the bolt through and tighten it down, but not fully tighten yet.
[attachmentid=43383]
Old Jan 21, 2006 | 07:19 PM
dustindu4's Avatar
Now swing the rear end of the arm into position, you will see a little problem.
[attachmentid=43384]
The axle has shifted out of position, this is why it's important not to disconnect both LCAs at the same time. Big thanks to Import Slaya for suggesting in his post to use a ratcheting tie strap to shift the axle back into position. I was already prepared for this and bought a $6 10 foot ratchet strap at Walmart.
I want to tell you that this will look backwards from the previous pics because I took different pics on both sides of the car.
Loop the long part of the strap around the axle like this.
[attachmentid=43385]
There's a hole in the chassis for the hooks to go in. Put both in here.
[attachmentid=43387]
Old Jan 21, 2006 | 07:27 PM
luckyeod28's Avatar
So when the axle shifts out of position, it will shift to the rear of the car? Is that correct?
Sorry to interupt.
Old Jan 21, 2006 | 07:36 PM
dustindu4's Avatar
Now your strap is in position and ready to shift back into place.
[attachmentid=43390]
Tighten the ratchet until the holes in the rear bracket line up with the LCA
[attachmentid=43391]
Insert the bolts and tighten all the way with a torque wrench to 129 lb-ft (175 Nm). That is Ford's factory spec. There were no instructions with the BMR arms. A lot of people here are saying to torque them to 75 lb-ft, that is not tight enough, I suspect this is what is causing some of their noise problems.
[attachmentid=43392]
Hook the ebrake cables back up and you're good to go.
I didn't pack the bushings with grease on the grease ports. I don't know if they are pre-greased or not. Again no instructions from BMR. My arms don't squeak or make a sound at all. I couldn't tell anyway because I installed Flowmasters at the same time. Did you guys grease yours?
Old Jan 21, 2006 | 07:37 PM
dustindu4's Avatar
Sorry to interupt.
I guess you didn't see this
PLEASE DO NOT RESPOND YET, I AM STILL ADDING STUFF ]
Old Jan 21, 2006 | 07:44 PM
dustindu4's Avatar
Here's the Ford factory service manual worksheet on the lower control arms
Old Jan 21, 2006 | 08:38 PM
outdoorstom's Avatar
This is the next mod on my list. Thanks for taking the time to write this up. Got a question. Can you leave your tires touching to the ground to avoid the axle shifting?
Old Jan 21, 2006 | 08:56 PM
cop on my back's Avatar
Dustin, sounds like you and I are doing the same thing to our cars. I have the BMR LCA's, Flowmasters, h-pipe, Eiback pro kit lowering springs and the BMR adjustable panhard rod.
Thanks for the write up, I will be taking the car off the road for a weekend in March and install everything.
So you don't find any extra road noise from the LCA's? I guess with the Flowmasters you wouldn't hear it anyways.
Old Jan 21, 2006 | 09:03 PM
dustindu4's Avatar
There's no way you can get in and have enough room for everything you need to do. No way that can be done. I think even if you had the tires on the ground, it would still shift. Don't worry about the shifting, it's not a big deal as long as you can reposition it with the tie strap.
Old Jan 21, 2006 | 09:04 PM
dustindu4's Avatar
Not really, I don't hear anything
Old Jan 21, 2006 | 10:25 PM
ryan1112's Avatar
When I installed mine I had to bore out the steel bushing on the side that is toward the back. It was to small. I have no idea why the back steel bushing is smaller than the front one. They didn't send any replacement bolts to fit it. Although I was able to bore them out fine and they are installed with no problem, I'm a little pissed that I had to do that.
Old Jan 21, 2006 | 11:16 PM
slammer223's Avatar
Thanks for the great write-up Dustin.
Old Jan 22, 2006 | 07:13 AM
If the car is on a ramp type lift you could do it. Davids2toys did it on his lift and it didn't shift. I agree about not being able to do it on the ground.
Old Jan 22, 2006 | 07:48 AM
Hatchman's Avatar
Nice writeup. I wish I had thought of the strap when I did mine. Let's just say, my method was much harder, and I counted that as my workout for the day.
Old Jan 22, 2006 | 09:09 AM
hawgman's Avatar
Sounds like you kinda got shafted because I got my LCAs from the same source that you did. They came with instructions, and it said very specifically to do them one at a time and not both at once because the axle would shift.
Dang..sorry you had to figure it out the hard way.
Old Jan 22, 2006 | 10:10 AM
Eleanor Dreaming's Avatar
Does MAK Performance on E-bay have about the best price on these? 119.95 incl shipping.
Old Jan 22, 2006 | 10:34 AM
That is where I got mine. Don't forget, free shipping!
Old Jan 22, 2006 | 10:43 AM
MaverickMLFD371's Avatar
When me and "cheese302" did mine on the car, we didnt need to remove the tires or tie a strap to it. We just did one LCA at a time and we got them both on in 30 min. No axle shifting occured....
Old Jan 22, 2006 | 11:05 AM
thump_rrr's Avatar
If you need to lube up any poly bushings use Energy Suspension Formula 5 Prelube. You can get it in either 3 x 1/2oz. squeeze tubes or an 8oz. tub. It's sticky like glue and doesn't wash off. I bought a tub of it for $12.00 a few years ago. I use it on everything from swaybar bushings,panhard bar bushings, third link and LCA bushings. I never use a grease gun on LCA's.
Old Jan 22, 2006 | 11:39 AM
dustindu4's Avatar
That's where I got mine. In fact BMR shipped me two sets of arms. I let them know and they sent UPS to pick them up. Neither box had the instructions with them. Unless it was way at the bottom of the box under the paper. I should contact BMR and ask them to email me them.
