Increased NVH with aftermarket strut mounts?
I recently installed the J & M camber plates, which resolved my "strut popping" issue. However, now there is noticeably more NVH being transmitted through the chassis. Seems like I can feel and hear the slightest road imperfection. I guess it makes sense since the factory mounts are plastic vs. the aftermarket metal ones.
How many of you guys with aftermarket strut mounts (Steeda, J & M, etc.) have this? Would some better struts improve this?
I have the J&M mounts and there is indeed more noise. At high speed it is not an issue as the road noise/wind/etc. drowns out the noise from the J&M mounts. While it may be normal, I'm going to revert back to the revised stock mount (Part Number 8R3Z-18183-B) because the noise I'm hearing at low speed is annoying.
9/24/15 08:15 PM
