important...what can it handle?
Old Feb 28, 2007 | 07:21 PM
GTracer's Avatar
Ok this is important, I am supercharging my car with the Whipple H/O kit and my friends keed telling me that I am stupid to spend that much money because I am going to crack my block with that much horsepower. Its going to make a little under 450rwhp. Is this true or am I safe to drive it?
Old Feb 28, 2007 | 07:24 PM
tom281's Avatar
well if you're already installing the kit, then its a little too late to worry about it now.
Seriously though, at that power level its all in the tune! Are you using the Whipple tune or a custom tune?
Old Mar 1, 2007 | 07:53 AM
TillmanSpeed's Avatar
Former Vendor
Tom's absolutely right. If you stay with a conservative tune, you will have no issues. When you get a custom tune, to pull the max horsepower out, you're going to jeopardize the longevity of your engine and transmission life.
CR
Tillman Speed
610-497-3711
Old Mar 1, 2007 | 09:14 AM
Error404's Avatar
I think the consensus is once you are around 450ish to the ground, that's the grey area. I'd plan on having some money (and time!) set aside just incase you break something in the motor.
I'm only having an 8psi pulley put on which should put me comfortably below 450, but I still have funding available just incase I break a rod or something. Be prepared, these motors weren't designed specifically to be supercharged like cobra motors are.
Someone posted pictures of the rods. First picture is the stock rods, second picture shows cobra rods:
Old Mar 1, 2007 | 09:27 AM
black sunshine's Avatar
Man that GT500 is a nice car......to bad it tips $70,000..
Old Mar 1, 2007 | 02:30 PM
don_w's Avatar
The block should be fine... the rods are what you need to worry about. That's probably the only way the block will crack, is if a rod goes through it!
NC14GT
Sep 10, 2017 04:47 PM
K.A.I.N
13
Dec 26, 2015 01:29 PM
GeoWett
Sep 30, 2015 06:40 AM
Ray11
Sep 25, 2015 12:43 PM
