I am personally building a new motor...
Old Mar 7, 2006 | 06:03 PM
Cleveland's Avatar
Alright...
The Ford Motorsport Cobra Crank can be had for $600 and requires the use of an 8 bolt flywheel/flexplate.
Am I correct that there is a particular flexplate that will fit this need AND fit for the 05+ Mustang?
It seems that I will be going with Manley H Beam Connecting Rods for $572.00 (part # 14042-8) and custom forged Big Bore (3.7") Pistons to up the total displacement to 305 (5.0 liters).
Im not quite sure what compression ratio I want to bring it (down?) to. I will eventually be throwing on a Supercharger, most likely a Kenne Bell.
-Dan
Old Mar 7, 2006 | 06:32 PM
thump_rrr's Avatar
<div class='quotetop'>QUOTE(Cleveland @ March 7, 2006, 8:06 PM) Quoted post</div><div class='quotemain'>
Alright...
-Dan
[/b][/quote]
Those rods are only good for 700HP translation 595 rwhp. [img]style_emoticons/<#EMO_DIR#>/dunno.gif[/img]
Old Mar 9, 2006 | 03:21 AM
Cleveland's Avatar
they are "rated" for 700hp, there is enough room to be safe. They arent going to fail @ 701 plus I think I will be very happy with ~600rwhp, I dont need anything crazy here. I just want to build a strong 5.0 liter block for nitrous use until I can afford that blower.
When I get a chance I'll get some answers from Manley on the big bore pistons for the 4.6 block.
-Dan
Old Mar 9, 2006 | 04:40 PM
mikem's Avatar
[img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/banana.gif[/img] [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img] Why not just yank out the 4.6 and drop a 5.0 in.I am actually thinking of doing this.Take out engine wrap it up and put it away.Buy a 750HP crate small block ford and just make motormounts,Throttle cable.C6 transmission,9inch ford rearend housing.Kick it old school and then when i am done put all the other stuff back in.
Old Mar 9, 2006 | 06:07 PM
Cleveland's Avatar
Cause I live in California, pulling the headers out in another 5 years is gona be tough enough. Changing out an entire wiring harness and motor is light years beyond that.
~$2500 gets me in the motor ballpark.
-Dan
Old Mar 9, 2006 | 06:51 PM
Cleveland's Avatar
I should also add that I have a built "Stroker" 385 Cleveland sitting right next to me. Forget the crate motor 5.0 in this case. The edge of "streetable" is defined by its .647" lift of cam and 300+ degress of duration on both intake and exhaust. If I wanted a "real" engine I already have that covered.
With that stated.... I want to work with the factory electronics, not against.
-Dan
Old Mar 10, 2006 | 09:36 AM
Rebel73's Avatar
<div class='quotetop'>QUOTE(70MACH1OWNER @ February 26, 2006, 2:38 PM) Quoted post</div><div class='quotemain'>
Hey Dan,
Well, I will offer you the opinion of a 52 yr. old motor head who has had experience with ford pushrod and mod motors. Stroker motors are great for about 20k in mileage before they wear out. Unless you have 15k to get a 5.0 Ford cammer motor and the electronics to go with it for only 400 hp than that is out. For my money I would investigate what it would take to put a 5.4 mod motor with supercharger in the 05. I presently own a 70 Mach 1 with a 351 Cleveland, had a 428 SCJ 69 Mach 1 and a 302 HIPO 68 Vert. But none of them would drive and out run this 05 with my present mods. I know you can put a 5.4 with supercharger in these 05's for way less than a GT500 and that's including a 6 speed.
Scott [img]style_emoticons/<#EMO_DIR#>/thumb.gif[/img]
[/b][/quote]
Hey,
this is also a topic of interest to me. Where do I look for the 5.4 block? Ford Racing? Thanks!
Old Mar 12, 2006 | 05:32 AM
70MACH1OWNER's Avatar
<div class='quotetop'>QUOTE(Rebel73 @ March 10, 2006, 11:39 AM) Quoted post</div><div class='quotemain'>
Hey,
[/b][/quote]
Hey Rob,
Personally if I was serious about putting a 5.4 supercharged engine in a 05, I would start my search by looking for a wrecked Lightning or Harley truck that already has the forged goodies and supercharger and than do a simple rebuild. Next stop would be Ford racing crate engines. They have a complete 5.4 crate engine for like 6k. This would be alot more expensive route. But you would know what you have.
Just my 02$
Scott
Old Mar 12, 2006 | 09:20 AM
thump_rrr's Avatar
Hey,
[/b][/quote]
JDM Engineering for their Ford GT based all aluminum 5.4L block.
I would guess that this motor is in the "If you have to ask" category.
Old Mar 12, 2006 | 09:37 AM
don_w's Avatar
And be prepared for a multitude of fitment and computer gremlins to solve. Swapping a 5.4 for the 4.6 is more than likely a lot harder than it sounds...
Old Mar 12, 2006 | 01:36 PM
<div class='quotetop'>QUOTE(don_w @ March 12, 2006, 11:40 AM) Quoted post</div><div class='quotemain'>
[/b][/quote]
I know you are correct in my heart. But how about a N/A 5.4 with carbs. Screw the computer!!!!!!
Scott [img]style_emoticons/<#EMO_DIR#>/drool.gif[/img] [img]style_emoticons/<#EMO_DIR#>/drool.gif[/img] [img]style_emoticons/<#EMO_DIR#>/drool.gif[/img]
Old Mar 12, 2006 | 02:13 PM
don_w's Avatar
<div class='quotetop'>QUOTE(70MACH1OWNER @ March 12, 2006, 12:39 PM) Quoted post</div><div class='quotemain'>
[/b][/quote]
Three words: Body in White [img]style_emoticons/<#EMO_DIR#>/04.gif[/img]
May 3, 2026 05:42 AM
kponypower
Jun 17, 2020 07:17 AM
