hurst shifter 1-2 inches of play
Old Oct 22, 2006 | 08:42 PM
abouttobeglue's Avatar
got mine installed today, installed correctly per instructions, i can pull up and move it about an inch or two, anyone else have this problem, know how to fix it, or is it supposed to? i hope not
Old Oct 23, 2006 | 06:32 AM
34124231user's Avatar
Something is definately wrong with your install if you have any play in the shifter. Are the upper 2 shifter bolts tight (the ones that hold the chrome shaft on). Pull the shifter cover up, and push the rubber cover down, so you can see everything. Move the shifter handle- if the chrome part moves, but the other one doesn't, then you need to have those 2 nuts re-torqued and they MUST have a LockTite on both of them. If everything up top looks good, then you either have a defective shifter, or somebody forgot to tighten up something underneath. Did they install the 2 plastic bushings in the bottom of the shifter? You have to remove the bushings from the old shifter bottom, and install them in the new shifter bottom, because the new one doesn't come with bushings.
Good luck to you. Sounds like a bad install to me.
Jul 8, 2016 08:53 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
robjh22
Sep 8, 2015 12:31 PM
