Hurst Classic Short Throw
Old Nov 21, 2005 | 04:29 PM
xetrov's Avatar
How difficult is the install on these? I don't know too much about cars other than how to change oil and tires, etc. Also, how does the shift boot work with it...or does it? Do you just remove it and leave whats under exposed?
Old Nov 21, 2005 | 05:28 PM
Mustang Kid's Avatar
It took me about an hour to install mine, but that was on a lift. You only need like 3 wrenches to put it in. You do reuse the shifter boot. They give you an adaptor piece that converts the top of the boot which is round to a oval shape that fits the handle. Looks really nice whens its done.
Old Nov 21, 2005 | 05:41 PM
xetrov's Avatar
What all does installing a shifter entail? Is it just removing a few bolts and switching them out, or is there some involved alignment you need to do?
Old Nov 21, 2005 | 05:51 PM
Ascout's Avatar
No special "alignment" is necessary. You should have a 13mm wrench, a 10mm wrench, and I HIGHLY recommend a 10mm DEEP well socket for the rear mounts....unless you enjoy endless turns on an open/box end and scarred hands.
Insert the Hurst shifter through the interior almost upside down...rotated about 150 degrees clockwise, then rotate when it's all below the tunnel. A helper is nice to have, but not essential if you secure it up there with tape or bungees so you can get underneath and attach the bolts/nuts. Some lithium grease for the shifter/tranny link is recommended, and I used threadlocker on the specifies connections (in the instructions)....I use the "blue stuff"...242, I think. No heat required for removal.
Took me about 1.5 hours working alone on ramps.
Old Nov 21, 2005 | 06:13 PM
xetrov's Avatar
Thanks for the response. I'm definately ordering one now..where did you get your ramps from?
Old Nov 21, 2005 | 07:46 PM
Ascout's Avatar
I got "Rhino" ramps from Autozone. They are synthetic plastic stuff, support 12,000 lbs. and light and easy to store. About $60. Some lighter rated ones are cheaper. They also have a 17 degree rise which gives you JUST enough to get under the car, but also mean the front valence doesn't interfere with the ramp necessitating a "pre-ramp".
trackpack13gt
Jul 25, 2017 05:29 PM
Jul 8, 2016 08:53 AM
yabutt
Oct 23, 2015 01:05 PM
Sep 16, 2015 06:44 PM
