How Does The Oil Filler Neck Detach From The Cam Cover?
Old Jun 3, 2007 | 09:34 AM
GRAYPNY's Avatar
It looks like it should come right off but it doesn't.
Old Jun 3, 2007 | 10:38 AM
70MACH1OWNER's Avatar
Hey Rich,
I when out and looked at mine and I believe it is just a press fit in the valve cover. At least that looks like the way it held in. I am assuming you still have the valve covers on your car. I think if once you take the cover off you my be able to gently tap it out from the inside.
Scott
Old Jun 3, 2007 | 11:16 AM
DavidM's Avatar
It has a cam lock style fitment. You twist it and it comes out. I can't remember which way counterclockwise I think. Two small tabs on either side of the neck slide into grooves in the cover and lock it in place.
Old Jun 3, 2007 | 12:38 PM
tom281's Avatar
That's correct, counter-clockwise.
Old Jun 3, 2007 | 12:48 PM
Pay no attention to me Rich. These guys proabably know what they are talking about!
Scott
Old Jun 3, 2007 | 01:13 PM
GRAYPNY's Avatar
Well there was a tab on the lower part of the neck before I broke it off but I don't see any tab on the top and that baby ain't moving so far.
Old Jun 3, 2007 | 01:32 PM
GRAYPNY's Avatar
OK, I stuck a socket handle in the tube for more leverage and that did the trick!
Attached Thumbnails How Does The Oil Filler Neck Detach From The Cam Cover?-228.jpg
Old Jun 3, 2007 | 02:10 PM
DavidM's Avatar
Great to hear Rich. I know when I took mine off it was stuck pretty good too.
Old Jun 3, 2007 | 02:15 PM
tom281's Avatar
Next question regarding the plug located beside the oil filler neck. I got mine unplugged and the connection removed, but do I need to remove the black, circular piece that the plug connects to? Atleast for powder coating anyway?
Old Jun 3, 2007 | 02:40 PM
travelers's Avatar
Yes when they power coat something after the apply the coating it goes into a oven and ehated to somewhere around 250 degrees. I know we had to replace some plastic bushing on two brake arms on a HD Bike because they melted.
Old Jun 3, 2007 | 03:28 PM
tom281's Avatar
Got it......
FYI, they're a press-in fit and are TIGHT! But, I got them out.
Old Jun 3, 2007 | 03:43 PM
DavidM's Avatar
I used a large socket from the back after I removed the cam cover and hammered them out. Installation reverse of removal.
Old Jun 3, 2007 | 09:46 PM
Stoenr's Avatar
I'm in the broken oil filler neck club, I would have been no help, lol.
It wasn't going back on anyways after the powder coating.
Old Jun 4, 2007 | 01:38 PM
S197 GT's Avatar
3rd Times A Charm
The proper tool always makes any job easier.
In this case Rich, I think you need some bigger dumbells!
wallace
Mar 29, 2016 10:09 AM
southern stang
Sep 26, 2015 04:19 PM
Bytor1960
Ecoboost
Sep 25, 2015 09:00 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
