how do i smoke my tires
Originally posted by tacbear@December 15, 2005, 10:06 PM
If you want to do a real good smoky burnout try this:
1) Turn off Traction Control.
2) Have someone pour water in front of your rear tires.
3) Roll into and out of the water puddle.
4) Put your car in 2nd gear.
5) Wind the RPM to about 4000.
6) Let the clutch out FAST.
7) Watch your Rpm and try to keep it between 4-5000.
8) As soon as your tires start spinning place your left foot on the brake and apply pressure until your car doesn't move forward, but no more than it takes to keep it from moving (continue to watch rpm's and keep them at about 4000)
9) When your car is engulfed in smoke you can let off the brake and slowly back out of the throttle. This can be done without the water, but wet tires spin easier!
Usually I dump it in first, get the tires nice and hot, then I smack 2nd gear and ride the brake out for as long as needed.
Originally posted by dustindu4@December 16, 2005, 7:22 AM
Sorry, they're over at my house. I'm finished with them now, you can have them back.
For the record the one on the left IS better
I can vouch for 4.10s!! I think I have an extra 10 lbs of rubbber stuck in my rear fenderwells now.
Originally posted by holeshot@December 16, 2005, 7:59 AM
Just a side note....the 05 GT's will not (or at least mine wont) do a burnout on dry pavement from just dumping it in 2nd gear from a dead stop. It smokes the clutch every time.
If you would have read the whole thing then you would see #2 says:
Originally posted by tacbear@December 16, 2005, 12:58 PM
Mine wouldn't do a good burnout NA without adding water
Did anyone mention this way to smoke your tires....
1)grind tires up in to small bits.
2)put ground up tires in rolling paper.
3)seal paper around ground tire.
4)light and enjoy...
Originally posted by NOLAGT+December 16, 2005, 1:15 PM--><div class='quotetop'>QUOTE(NOLAGT @ December 16, 2005, 1:15 PM)</div><div class='quotemain'>I always have loved that picture!
[/b]
[/b]
Me too.
I have dozens (hundreds?) of shots like that.<!--QuoteBegin-Knight@December 16, 2005, 1:18 PM
[/quote]
Yep, close... see Post #2
this will get the job done. Even though it's cheating
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
