HOW CAN I SMOKE THOSE TIRES
Old Jun 5, 2005 | 10:38 PM
169stang's Avatar
[attachmentid=23459][attachmentid=23458]Line locks for these cars are 2 solenoids inline of the front brakes. Depress the brakes to build brake pressure, push the button, let the foot pedal go. I personally, lock the lines, rev to 5000, let the clutch out in 3rd gear-which heats the tires faster. The solenoids retain the brake pressure only at the front tires. If you let the button go, brake pressure is released. Example burnout:
http://2005stang.com/viewtopic.php?t=331
You really can't inch forward and then stop again with line locks, atleast not the type I have. I haven't tried to do so. You can buy a kit from here.
http://secure-order-area.net/paulshp/cgi-b...d=2414378_14456
Before the line locks, I used to push on the gas with the ball of my right foot while sitting on the brake with my right heel and let the clutch out quick at 3000 rpm. This, I promise, will wear out your clutch the most and your brakes as well. I've already replace my clutch, if you don't believe me. The line locks are fun. If I had to do it over again, I would have installed the button under the shift boot. It's currently between the shifter and the console. You can press it while driving, but it doesn't do anything. You have to build pressure before it will lock the front brakes.
Old Jun 5, 2005 | 10:44 PM
Fazm's Avatar
In the v6 area i have a video of me doin a brake stand without very much forward movement. Its not that hard
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
