Hot Running GT
Hot Running GT
I had my car back to the stock oem tune and airbox for the last few days. The first thing that I noticed is that the car was running hotter than with a custom tune and cold air kit. I have an autometer water temperature gauge and and it was running 200 on the highway and getting up to 215 in stop and go traffic.
After putting the cold air kit back on today with the new JLT version II pipe and loading a 91 octane custom tune it was running 190 highway and 195 in city traffic. I changed the version I tube and tunes out for the version II tube and tunes. It ran around 190 then too.
I doubt that many people have autometer or high performance water temperature gauges on their stock Mustangs, but I would like to know if anyone else has seen this?
Haven't seen that diff cause I didn;t have a temp gauge when stock
but can say that my average temp (and at least a few others) is 195 right on the nose
(since installing my CDC black billet grill though, on the highway it drops to 190 with the improved airflow)
I agree that our stock stangs should not run that hot. Since I have put the Aeroforce gauges in a couple of weeks ago I agree with the others that I am running 190-195 degrees with tunes. I have made two 7 hr round trips the last couple of weeks and my temps never went over 195 running 80 mph on the highway. In the old days we put 180 degree thermostats in our cars for better performance but "they" claim we don't want to do that with these cars. Why?
Scott
If I'm not mistaken Normal Operating Temp is in fact 210.
Thermostat does not even open up until 195
As for installing a lower temp thermostat it is not recommended due to the engines being designed to run at higher temps. When you start lowering the temps to much the ECM thinks the vehicle is cold and starts dumping more fuel in.
You could alwasy install the Ford Racing Radiator though
Richard
Richard
Richard
Richard
If you are correct about the engines needing to run warmer wouldn't the ECM just fight a larger radiator also? It seems it would without the tune correcting for it.
Scott
I agree water wetter helps tranfer heat. But it would seem if our tunes call for the engine temps to be in the 190-195 degree range not even a larger radiator will help if the ECM is programed for 190/195. Correct? It's not like our radiators are not capable of cooling these engines. After all they run the same temps in Phoenix in the summer. It comes down to the thermostat and computer programming...I think.
Scott
Scott
GT's thermostat starts to open at 180. At highway speeds my temps are 190-195. I adjusted my fan speeds so they match the stock settings. I set it at 214 and 225 for low and high speed fans, just like stock.
At highway speeds, having the fan on is not going to lower the temps. It's already getting plenty of air, it's all about the thermostat.
IMO I think water wetter is only useful necessary for deficient or cooling systems on the ragged edge. If this engine cooling system can accommodate a intercooled Whipple at 10 PSI, then I seriously doubt the factory radiator is at its limt with the car naturally asperated, else Ford would have Whipple adding a bigger radiator to the kit.
