Horsepower
Old Dec 17, 2004 | 11:50 AM
SurfnSoCal's Avatar
My buddy told me that figuring Horsepower at the wheels is different for each car?
Is there a formula for the 2005 Mustang GT for figuring hp at the wheels?
I searched to no avail...
thanks!!
Old Dec 17, 2004 | 11:58 AM
adrenalin's Avatar
Pretty much stick it on a Dyno to find out what you have because it does vary for each vehicle.
Old Dec 18, 2004 | 05:10 AM
The Boss Hog's Avatar
Yes, it does vary with each car but you can get a reasonable estimate by figuring a 15% lose for a manual or a 18% lose for an automatic.
Example: 300 hp advertised at the flywheel equals about 255 hp at the rearwheels on a manual.
The '05 Mustang with a manual is getting from 265 to 275 hp at the rear wheels so it looks like Ford is under-rating the flywheel hp by 10 to 20 hp.
The Boss Hog
Old Dec 18, 2004 | 09:00 AM
RRRoamer's Avatar
Has anyone had the driveline loss measured when their car was on a dyno? A good dyno can measure actual driveline loss just about as easy as it does engine power. Then you KNOW what the loss is instead of the "rule of thumb" is only a gross estimate at best....
Old Dec 18, 2004 | 01:14 PM
Fordracing200's Avatar
a 05 was dynod stock with 300 rw ft-lbs and 276 rwhp
Old Dec 19, 2004 | 01:18 PM
geoffpelosi's Avatar
"The '05 Mustang with a manual is getting from 265 to 275 hp at the rear wheels so it looks like Ford is under-rating the flywheel hp by 10 to 20 hp"
Woah woah woah, what happened to the advertised 300 hp mustang!? I ordered my 2005 Mustang under the, ostensibly false, pretenses that it puts out 300 hp and that I would be building on it from there... is this true or what's going on here??
Old Dec 19, 2004 | 01:42 PM
TomServo92's Avatar
They're talking about rear-wheel horsepower. The 300HP rating from Ford is for fly-wheel horspower. 265-275 rear-wheel horsepower equates to around 311-324 fly-wheel horsepower for a manual tranny car. That means that Ford's 300HP is underrated.
Old Dec 20, 2004 | 04:33 PM
Black Magic's Avatar
Go to slowgt.com and click on racers math. That is a good source to figure out power without a dyno if you run at the track.
Old Dec 20, 2004 | 04:37 PM
SurfnSoCal's Avatar
awesome. So it would be a safe bet that the 05 Stang is actually 310-320hp then. And for sure those numbers with a good intake setup and exhaust.
Old Dec 20, 2004 | 11:59 PM
BillP's Avatar
The car has a great exhaust already.
The best Magnaflow could do with it on a stock motored 05 Stang was a 5hp increase.
310 or so is an accurate guesstimate for the crank.
09-gt/cs
Oct 15, 2015 10:03 AM
AdPock
Sep 22, 2015 05:55 PM
Stephen Laslo
V6
Sep 18, 2015 07:57 PM
mustangsally_
Sep 18, 2015 05:35 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
