Horsepower
My buddy told me that figuring Horsepower at the wheels is different for each car?
Is there a formula for the 2005 Mustang GT for figuring hp at the wheels?
I searched to no avail...
thanks!!
thanks!!
Yes, it does vary with each car but you can get a reasonable estimate by figuring a 15% lose for a manual or a 18% lose for an automatic.
Example: 300 hp advertised at the flywheel equals about 255 hp at the rearwheels on a manual.
The '05 Mustang with a manual is getting from 265 to 275 hp at the rear wheels so it looks like Ford is under-rating the flywheel hp by 10 to 20 hp.
The Boss Hog
The Boss Hog
Has anyone had the driveline loss measured when their car was on a dyno? A good dyno can measure actual driveline loss just about as easy as it does engine power. Then you KNOW what the loss is instead of the "rule of thumb" is only a gross estimate at best....
"The '05 Mustang with a manual is getting from 265 to 275 hp at the rear wheels so it looks like Ford is under-rating the flywheel hp by 10 to 20 hp"
Woah woah woah, what happened to the advertised 300 hp mustang!? I ordered my 2005 Mustang under the, ostensibly false, pretenses that it puts out 300 hp and that I would be building on it from there... is this true or what's going on here??
AdPock
Sep 22, 2015 05:55 PM
That is a good source to figure out power without a dyno if you run at the track.
