Help me find a Rattle and a transmission issue
Old Mar 4, 2010 | 06:26 PM
gremlin190's Avatar
Hey guys, I need some assistance.
I just got my Kooks headers installed and I get a strange rattle everytime I make a left turn or I accelerate hard. It comes from the passegar side and I can't point my finger to it. It's seems to be around the firewall. I thought it was the heat sheild by the shifter, but that was removed so that isn't it. It appeared when I got them installed.
Also, I have a manual transmission and when I down shift to 2nd I get a strange rattle/no oil in a bearing sound. i have the MGW short shifter adjusted to 7 turns. Do you think my synchro is going bye-bye? Or is it something maybe with the shifter? It begins when I pull the shifter to the driver side and doesn't go away till I pop it into 2nd
Old Mar 4, 2010 | 06:28 PM
Whosit's Avatar
I get the same noise in the tranny if I shift down at a high rpm. So same question.
Old Mar 4, 2010 | 06:29 PM
gremlin190's Avatar
That exactly the problem. Mine is intermittent. Do you have a short shifter?
Old Mar 4, 2010 | 06:35 PM
Whosit's Avatar
nope. Someone mentioned it was something to to with the through out cylinder and there was not much I could do about it. I also get a rhythmic squeaking in neutral that goes away when I push the clutch in.
Old Mar 4, 2010 | 06:49 PM
gremlin190's Avatar
ha with those hotrods, your lucky that's the only sound you get. Mine sounds like something is struggling to turn and then you push the clutch in and all is fine
Old Mar 5, 2010 | 07:32 AM
Commbubba19's Avatar
That is a sign of a worn throwout bearing.
Old Mar 5, 2010 | 08:06 AM
gremlin190's Avatar
I had something similar on my nissan pickup and it was the pilot bearing
Old Mar 5, 2010 | 07:20 PM
Whosit's Avatar
Thought these cars didn't have throwout bearings?
Old Mar 6, 2010 | 10:33 AM
cop on my back's Avatar
All manual transmissions have throwout bearings.
Old Mar 6, 2010 | 03:18 PM
Whosit's Avatar
That's what I thought but was told one these cars it's a hydraulic piston?
Old Mar 6, 2010 | 04:00 PM
70MACH1OWNER's Avatar
Your both correct. They have a hydraulic actuator that powers the throw out bearing. That disengages the clutch.
Old Mar 6, 2010 | 04:20 PM
Whosit's Avatar
Ok so then maybe I do have a bearing going bad then... That's what I thought but someone told me I didn't have one and the noise is something I would have to live with... Guess I will price replacing it.
Old Mar 6, 2010 | 04:28 PM
gremlin190's Avatar
The part will be cheap :0 it's the labor of dropping your transmission that will cost you
In addition to the throw out bearing, I've read about issues with the pilot bearing - where the transmission shaft mates with the crankshaft.
On another car I had the pilot bearing would squeal or bind after 30 or 40k. So the second time I fussed with it I threw the bearing out and had an oil-lite bronze bushing machined. No more problemo.
Old Mar 9, 2010 | 10:20 AM
gremlin190's Avatar
Update!
it looks like my headers were rubbing slightly on the passenger side. We moved the motor ever so slightly and that has seemed to fix the rattle.
05GT4.6
Sep 7, 2015 11:06 PM
apial
Sep 6, 2015 10:40 AM
ssjbuu
Aug 28, 2015 08:55 AM
trackpack13gt
Aug 8, 2015 11:23 AM
Mug-stang
Jul 31, 2015 10:25 PM
