Help me figure this out...
Old Jun 23, 2005 | 11:40 AM
SurfnSoCal's Avatar
1. Had the stock intake installed, with the HC removed; and installed the Predator 91 octane tune. Ran like a champ. Drove the car for a couple months. 17-18 mpg.
2. Disconnected the battery, installed the K&N intake, re-connected the battery and drove the car for a week. 14mpg. Noticed the car getting slower and not as quick (in reving).
3. re-flashed the PCM with the 91 octane tune.
car runs much much better.
so by disconnecting the battery when I installed the K&N intake, and this resetting the computer; I fouled up the tune? :scratch:
this doesn't seem right...
Old Jun 23, 2005 | 12:07 PM
porsche's Avatar
sounds ok to me you should of re set from the get go. now dyno it for max performance.
Old Jun 23, 2005 | 12:13 PM
SurfnSoCal's Avatar
so by leaving the battery disconnected...and resetting the computer...I also needed to re-install the Tune AGAIN?
Old Jun 23, 2005 | 12:19 PM
porsche's Avatar
no , everytime you change a part like intake or headers you shoul reset the computer so it re learns!
I would bet its lean after the k@N!
i DONT CARE WHAT THE KIT SAID !
when you put the tune in it changes the air fuel curve to around 13.1 from stock 12.1 and the intake does the same so your lean!
Old Jun 23, 2005 | 04:21 PM
SurfnSoCal's Avatar
ok so install the new part, reset the computer, then install the tune. so I should reset the computer, then without starting the car....install the 91 octane tune; then run the car so it learned??
is this what you are saying?
Old Jun 23, 2005 | 04:24 PM
rrobello's Avatar
TMS West Coast Correspondent
I installed my intake and let the comp relearn idle like it says to after reconnecting battery, no tune and the mileage didnt change except on the freeway its slightly better but only when cruisin at higher speeds (90mph better than 80)
Old Jun 24, 2005 | 07:23 AM
adrenalin's Avatar
wait a minute. You installed a tune before getting the K&N but when you put the K&N in you didn't retune the PCM for it? You should have gotten a different tune.
Old Jun 24, 2005 | 08:11 AM
outdoorstom's Avatar
K&N advertises that a tune is not necessary with their CAI.......
Old Jun 24, 2005 | 08:14 AM
porsche's Avatar
True with a stock car not one with a performance tune in it.
Old Jun 24, 2005 | 10:33 AM
SurfnSoCal's Avatar
what different tune John?
I would love to find a K&N tune somewhere.
My question was...and still no one has answered-
Tune is installed - unhooked battery, installed K&N - ran car. Do I need to REINSTALL the 91 OCTANE TUNE after UNHOOKING the battery? Or Once you flash the PCM...is it flashed untill you flash something different.
Old Jun 24, 2005 | 11:08 AM
porsche's Avatar
no you dont have to flash after the battery re-set!
But ,you should take it to a dyno to tune just add fuel where it is lean.
try to get 13.1 across the chart. :shock:
Old Jun 24, 2005 | 11:59 AM
softbatch's Avatar
I talk to cones.
When you disconnect the battery you erase the computer so it went back to relearning a stock based tune. By reinputting the 91 octane tune you made the tune performance again.
Old Jun 24, 2005 | 12:21 PM
SurfnSoCal's Avatar
I'm so confused. People keep contradicting each other.
I understand I should go get it dyno tuned, but in what order should I
1. reset the battery and 2. install the 91 octane tune
Old Jun 24, 2005 | 01:34 PM
porsche's Avatar
your car will not go back to the stock tune unless you put it back.
You could have the battery out for a year.
But your car needs to learn the diablo tune and adjust so when you change your air intake its :bang: does not know what it going on and holds back on the power till it re-learns it self.
Old Jun 24, 2005 | 02:22 PM
SurfnSoCal's Avatar
ok, so should I do this-
flash back to stock tune
reset computer by unhooking battery
hook up battery, let car idle and "learn" the K&N
Instal 91 Octane tune...let car "learn tune"
does this sound right?
Old Jun 24, 2005 | 02:24 PM
porsche's Avatar
you dont have to take out the diablo tune so skip that part.
1. unhook battery
2. install air intake
3. hook up battery
4. let car idle re-learn
5. go to dyno
6. adjust a/f
Old Jun 24, 2005 | 02:35 PM
porsche's Avatar
1. unhook battery
3. hook up battery
5. go to dyno
6. adjust a/f
You should not ever have to re install your tune unless you make changes while on the dyno!
Spend the 50 bucks
I will bet its running lean.
Old Jun 24, 2005 | 02:41 PM
SurfnSoCal's Avatar
is that all it will take? $50? I thought most dyno places were $200 an hour
Old Jun 26, 2005 | 06:43 PM
ILikeBond's Avatar
One quoted me $500 for a tune. Not dependent on time. Seems steep.
Old Jun 26, 2005 | 06:49 PM
Greywolf's Avatar
Take a chicken foot dance around the car naked chanting Brad is King Brad is King then your Stang will run great.
CiniZter
25
Apr 28, 2016 05:41 PM
Christopher Fox Wallace
Sep 26, 2015 11:55 AM
Sep 23, 2015 03:21 PM
DrVet
Sep 23, 2015 01:48 PM
