Help with Hurst
Old Apr 30, 2008 | 08:39 PM
SS05GT's Avatar
Help with Hurst
I installed a Hurst billet shifter tonight. As far as I can tell, I followed all directions exactly, with the exception of spinning the stick 180 degrees from what is in the directions so that the handle is in the right direction and centered. The shifter feels fine and engages all gears. The problem is that when in any gear, the shifter has tremendous side to side movement, almost like the trans is in is in neutral. This can't be right, can it? Any help would be appreciated.
Old Apr 30, 2008 | 09:09 PM
shaun_beauchamp's Avatar
http://www.fordmuscle.com/archives/2...fter/index.php
When you are in first or second gear, the lateral movement should be minimal. If as you stated it feels as if it is in neutral, you have something incorrect in your install.
Refer to the above link and see if you can find the issue. If not, PM me and I'll do some more digging.
Old May 1, 2008 | 02:51 PM
SS05GT's Avatar
Shaun
Thank you very much for that link. I found the issue and all is now good.
Old May 1, 2008 | 09:08 PM
Great. Enjoy the 40% reduced throw!
Jul 8, 2016 08:53 AM
dbrinkley2008
Sep 9, 2015 07:02 AM
Mackitude
Aug 13, 2015 01:05 PM
area5179
33
Mar 4, 2006 04:04 PM
davids2toys
05-09 Exterior Modifications
15
Jul 18, 2005 11:56 PM
