Help car acts like it vapor locks.
Old Jun 11, 2013 | 10:00 PM
true fusion sports's Avatar
My 06 mustang acts like its going to stall I have a automatic and it just hit 18000 miles please help me. It sucks when your at a stop light and want to give it some gas and it acts like its going to die.
Old Jun 12, 2013 | 06:13 AM
dly's Avatar
dly
Clean your maf senser and your TB.
Old Jun 12, 2013 | 06:17 AM
texastboneking's Avatar
Bear Eats King...
Bear ****s Bone
More info needed....
Old Jun 12, 2013 | 01:38 PM
I checked the mass air very clean but maybe I missed something.
Old Jun 12, 2013 | 02:30 PM
Corstang427's Avatar
Did you change spark plugs?
Old Jun 12, 2013 | 03:59 PM
Hasn't misfired no codes very wired acts like a glitch.
Old Jun 12, 2013 | 05:07 PM
Bear Eats King...
Bear ****s Bone
Still this^^....
Need info man. To many things can cause your symptoms. . Need to know what you have tried doing to correct the problem. Need info on the variables. Engine cold? Warm? After long drive? Mods to the car?
Old Jun 12, 2013 | 07:37 PM
This happens after a long drive and I stop at stop lights it stuffers I've tried everything you guys told me to
Old Jun 12, 2013 | 08:40 PM
muscledom's Avatar
Fuel pump driver module. Mine finally glory crapped and threw a fpdm failure code. Hard to test for though. Mine was a little different, lost power while rolling. Left it sit for a whilst and the symptom would disappear. Went a year between failures. At first it only threw a low fuel pressure code. And if dorman makes something it's def a problem part. There is also a TSB for your symptoms, aeration in the fuel due to the pumps.
Old Jun 12, 2013 | 09:25 PM
18000 miles is all this beast has is their a fix for it. I've only had this car a month don't know much about it but it like to cut out at stop lights
Old Jun 13, 2013 | 05:15 AM
muscledom's Avatar
Take it to a mechanic buddy
Old Jun 13, 2013 | 05:29 AM
Bear Eats King...
Bear ****s Bone
yeah.... the lack of info makes it too hard to diagnose online...
Old Jun 14, 2013 | 12:29 PM
pinn's Avatar
Fuel Pump TSB 06-9-9. Air bubbles get trapped in the pump which causes the hesitation.
Old Jun 14, 2013 | 05:42 PM
ski's Avatar
ski
This ^
Only solution is to replace the fuel pump.
Old Jun 14, 2013 | 05:54 PM
Thanks guys that's sounds like what's going on faulty fuel pump that sucks such low miles but old car.
Old Jun 15, 2013 | 11:40 AM
Is their any type of recall for the tsb -06-9-9?
Old Jun 16, 2013 | 08:46 AM
ski's Avatar
ski
Nope.
Ecostang
Nov 3, 2022 08:50 PM
jc46002003
Apr 15, 2016 03:00 PM
f1-cobra
Aug 1, 2015 08:02 PM
HMR-TYM
Jul 31, 2015 10:39 AM
stewarts359
Jul 21, 2015 03:39 PM
