Headlight/foglight upgrade info
Old Mar 25, 2005 | 10:33 AM
tech's Avatar
I saw this on Corral, If it's a repost...oops.
What bulbs are available for the new 2005 Mustang GT
You should not try to upgrade any parts on your vehicle unless the original part number is contained in the upgraded part number. What I mean by that is you should not try to replace part 9145 with any part that does not contain 9145; you should not attempt to use part 9006 or 9005 in the place of part 9145. The only parts used in your vehicle that we offer any kind of an upgrade for would be your headlight and your fog light.
FOG LAMP 9145
Upgrade=9145ST (to be released in June 2005)
The SilverStar (ST) will offer a crisper whiter light than offered by stock and increase of approximately 20% more useable light than stock.
HEADLAMP H13
Upgrade=H13XV
The XtraVision (XV) will offer the same color of light as stock but approximately 15% more useable light than stock. There is no SilverStar (ST) upgrade available for part H13. Unfortunately, we will not be adding this part to our SilverStar product line at this time. The National Highway Traffic Safety Administration wrote it into specification that this bulb cannot be coated. Although we can request a waiver, this is not currently in progress.
We would not recommend that you deviate from what the manufacturer has placed into any application. They have done the necessary testing to ensure that the lamps will function safely in their particular application. It is possible that you might damage the assembly due to heat emitted from a different bulb. Please do not hesitate to contact me if you have any other questions.
Sincerely,
Heather
OSRAM Sylvania
Customer Service
Old Mar 25, 2005 | 02:45 PM
subzero05's Avatar
Put in the 9005 silverstars in your fogs and you will be VERY HAPPY!..done this months ago and talked at length about it...H13 headlamp bulbs are not avail yet from any major MFG, but www.novareindustries.com is working on one
Old Mar 25, 2005 | 03:15 PM
DarkRed's Avatar
I really want Xenons on mine, but the conversion kits are so much...
Old Mar 25, 2005 | 03:48 PM
PONY XPRESS's Avatar
Do my fog lamp conversion if your serious about your lighting. Best bang for the buck. See sig.
cameron2581
'10-14 Interior and Audio
Nov 26, 2015 01:26 PM
boz
Oct 1, 2015 04:47 PM
GeoWett
Sep 30, 2015 06:40 AM
GLOCKer
Sep 28, 2015 05:20 PM
