GT500KR Lower control arms
hello all...
while at the NY autoshow, i had a chance to look under the GT500KR and noticed the Lower Control arms are NOT level with the ground. they are from axle back, they are pointing slightly downwards.
i did notice that they are BULLIT aluminum LCAs
comments? is this out of spec? not optimal?
thanks!
thanks!
if they are pointing down from the body then that is normal and good but if they are pointing up from the body then that is not a good sign, that is why the relocation baracket is used so it can make the LCA point down from the body, also do you mean Billet LCA
starting from the axle bracket they are pointing downwards slightly because the GT500KR has lowering springs.
i was told that the control arm being LEVEL with the ground is factory spec.
hence relocation brackets.
thanks!
thanks!
