GT weight loss program
Old Aug 10, 2008 | 10:18 PM
rivercitypony's Avatar
I've seen a lot of information on reducing the weight of our stangs. Some had the specific amount of weight that would be lost for each specific mod. However, I have seen no consistent information for the rear seat delete kits available for the S197. I'm 6' 2", and nobody I know can fit in my back seat when I'm driving. Besides, Ford should have designed our cars (or given the option) to have no rear seat anyway! It seems like an inexpensive way to further reduce weight. I've seen statements of 20 to 40 pounds. Obviously this includes removing all the connecting and seat belt hardware as well. Anyone have any opinions on rear seat delete kits? MMR and Americanmuscle are two kits I've seen, so far. Also, are there any installation issues with this mod?
Old Aug 11, 2008 | 05:30 AM
I don't know about the rear seat delete but removing your spare tire and jack is about 30lbs
Old Aug 11, 2008 | 09:07 AM
Thanks, but I already did that, along with removing the shaker 1000 subwoofer and its amps. Some of my other mods have help reduce weight also (aluminum driveshaft/flywheel and off-road h-pipe). With everything I've done to lighten my GT, I know pretty how much weight has been reduced from the car. That's why I'm trying to find how much weight is lost with a rear seat delete kit. It's certainly not an appearence mod, in my opinion. It's not as clean a look as having a rear seat, but I'm cutting weight off the car by ridding myself of a useless item.
Old Aug 11, 2008 | 09:41 AM
Pwny's Avatar
Maybe this will help?
http://www.mustangcollective.com/sho...d.php?p=211324
This was done by Rygen. I plan on following some of th things here in the future.
Old Aug 11, 2008 | 11:18 AM
SlamMan02's Avatar
Rear seat delete is around 30-40
Old Aug 11, 2008 | 11:23 AM
officespace56's Avatar
Whenever I pull out the back seat to do audio stuff, it definitely .doesn't feel like 30 pounds..
Old Aug 11, 2008 | 11:24 AM
LEO_06GT's Avatar
I removed and weighed mine a while back and it's only 23lbs.
Old Aug 11, 2008 | 11:40 AM
karman's Avatar
Don't forget to drain the windshield washer reservoir.
Old Aug 11, 2008 | 11:51 AM
Pwny's Avatar
Thanks for weighing it. This seems a little more realistic.
Old Aug 11, 2008 | 02:15 PM
MTAS's Avatar
1-piece aluminum or carbon fiber DS will knock 30lb off
Old Aug 12, 2008 | 10:34 AM
Burke0011's Avatar
Big Falken Tires
I heard that too
Old Aug 12, 2008 | 11:10 AM
LEO_06GT's Avatar
You can lose 46lbs off the front end with a BMR K-member and radiator support/swaybar delte kit.
http://www.bmrfabrication.com/2005MustangCHASSIS.htm
Lose another 11lbs off the front with new A-arms.
http://www.bmrfabrication.com/2005MustangSUSPENSION.htm
Old Aug 12, 2008 | 03:35 PM
SlamMan02's Avatar
Bummer, Ive been wrong before - but I swear I read a big list and it had the rear seat/accessory hardware at 30-40 pounds... :shrug:
Old Aug 12, 2008 | 04:16 PM
LEO_06GT's Avatar
The only hardware is 4 bolts which all together can't weight more than 1.5lb if that.
Old Aug 12, 2008 | 07:39 PM
krnpimpsta's Avatar
The rear seat feels like 10lbs in my hands, but given that it's really 23lbs, maybe the 30+lbs figure comes from also removing the seat backs? I could see those weighing about 10lbs. (Or does the 23lbs include that?)
Old Aug 12, 2008 | 07:57 PM
Cavero's Avatar
Having removed the entire rear seat, it feels like the whole thing is maybe 25lbs if that. The numbers I've heard on the stock driveshaft are 46lbs and the Coast aluminum driveshaft weights about 17lbs. So pretty close to 30 lbs, yeah.
Old Aug 12, 2008 | 09:30 PM
The new MMR rear seat delete arrived today, and I just finished installing it. Removed the rear seat and seat belts, along with every nut, bolt, bracket I could find. Weighed everthing, and it totalled around 30 lbs. I was hopng for a larger number than that, but at least the fitment of the MMR kit looks clean. Oh well, time to start saving for lighter rims, lol. Btw, the entire removal/install should take about 30 minutes if you have the right tools. You'll need a standard socket set and a large Torx bit (3/8") to remove all the hardware.
Old Aug 13, 2008 | 08:12 AM
LEO_06GT's Avatar
It was 23lbs including the seatbacks. Only thing I didn't remove were the the brackets for the child seats and I guess the seatbelts if you want to count that.
Road_Runner
Sep 2, 2024 04:46 PM
CiniZter
25
Apr 28, 2016 05:41 PM
Sep 8, 2015 10:45 AM
earl610
Sep 6, 2015 05:48 PM
Kestral
Sep 5, 2015 11:50 PM
