GT 500 / Brembo Brake Upgrade Questions
Old Jan 13, 2010 | 10:44 PM
msully's Avatar
For those of you that have converted your GT to the GT 500 brakes, how much of a difference did these make? When I went to 19" rims and 275/285 tread recently I noticed a loss in braking performance so I am thinking about these as an economical upgrade. I upgraded the stock pads preoviously and they made a difference but I think I need more.
Also does anyone know if the Saleen heritage 19" wheels will fits with the Brembos without spacers?
Finally I am going to go to ss lines as well, what brand is best bang for buck?
Old Jan 14, 2010 | 08:29 PM
Import-Slaya's Avatar
What pads are you running? What tires? Going to the Brembos makes a slight difference in pedal effort, but at the end of the day your tire dictates your braking performance. I would suggest trying a more aggressive pad first. Also a good flush of the brake fluid will firm up the pedal feel.
FWIW, when on the stock front calipers with EBC yellow pads (at temp), running 275 R-compounds, I could still activate the antilock. The most noticeable difference I now notice with the Brembos is they completely resist fade on the track and they are easier to modulate during trail braking.
Old Jan 17, 2010 | 06:59 PM
Jaden's Avatar
I noticed better high speed braking with the Brembos. Probably because they don't fade like the stock brakes.
Old Jan 18, 2010 | 04:24 AM
skullzero's Avatar
have a set of brembo's gran turismo on 19in wheels and they do stop on dime.
Old May 31, 2010 | 07:26 PM
tam85's Avatar
i have gt500 brembo brake setup on my brother's gt. i got it here in our local car shop and paid for just $500.
Old May 31, 2010 | 08:02 PM
PIKE2244's Avatar
Where are you from??? Where is such a shop???
Old Jun 3, 2010 | 10:54 AM
Ninjak's Avatar
Running the Saleen Stoptech on my 08, and yes there is a truly different feel than the stock ones. No more fade, and braking from high speeds is def more controlled. Also they look BAD-AZZ !!!
Bought em for 700$ and installed myself. Was a snap really.
Old Jun 3, 2010 | 11:19 AM
todd03blown's Avatar
my assumption is yes since those wheels are also on the gurney car that has the 6 piston caliper's.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Jul 30, 2015 06:47 AM
Coyote5-0
Jul 17, 2015 03:47 PM
