GT 500 / Brembo Brake Upgrade Questions
For those of you that have converted your GT to the GT 500 brakes, how much of a difference did these make? When I went to 19" rims and 275/285 tread recently I noticed a loss in braking performance so I am thinking about these as an economical upgrade. I upgraded the stock pads preoviously and they made a difference but I think I need more.
Also does anyone know if the Saleen heritage 19" wheels will fits with the Brembos without spacers?
Finally I am going to go to ss lines as well, what brand is best bang for buck?
What pads are you running? What tires? Going to the Brembos makes a slight difference in pedal effort, but at the end of the day your tire dictates your braking performance. I would suggest trying a more aggressive pad first. Also a good flush of the brake fluid will firm up the pedal feel.
FWIW, when on the stock front calipers with EBC yellow pads (at temp), running 275 R-compounds, I could still activate the antilock. The most noticeable difference I now notice with the Brembos is they completely resist fade on the track and they are easier to modulate during trail braking.
Running the Saleen Stoptech on my 08, and yes there is a truly different feel than the stock ones. No more fade, and braking from high speeds is def more controlled. Also they look BAD-AZZ !!!
Bought em for 700$ and installed myself. Was a snap really.
whysoserious
05-09 Interior and Audio Mods
Oct 27, 2023 06:42 PM
Jul 30, 2015 06:47 AM
