Got question on header install
Old Jul 26, 2010 | 08:38 PM
dash's Avatar
Getting ready to do JBA long tubes. Can I use ramps or does the car have to be up in the front on stands. I guess if I need to move steering ramps are out?
Old Jul 26, 2010 | 11:48 PM
Shigetas's Avatar
Well as I have just barely completed one side of a JBA shorty install. Yeah you could use ramps but you will need a floor jack to jack up the motor off the mounts in order to get them in. I don't think the steering needs to be moved, just disconnected and moved out of the way as it goes right through where your manifold is.
Good luck it was a beeaaatch.
Scotty
Old Jul 29, 2010 | 02:25 AM
ETNOATS's Avatar
A high quality jack and jack stands will also give you more clearance, which is most important.
Old Jul 30, 2010 | 10:12 AM
d_bone33's Avatar
hmmm, well this don't even sound fun anymore to me....i was looking forward to coming home and installing the headers, mid pipe, and the exaust in a matter of an hour...but now it seems thats not possible lol
Old Sep 11, 2010 | 05:47 PM
wht67's Avatar
I just installed Dynatech headers on mine and it is no 1 hour job! I took my time and set aside an entire weekend to make sure I could complete it. I would say I spent almost 10 hours over the course of 3 nights. I did it completely by myself and it was a challenge but I am very happy with the results. A local shop wanted $600 to do the install so it was worth it to do it myself. I probably wasted an hour and a half or so raising and lowering the car at the beginning/end of each work session because I could not close my garage door with it up on the stands. (I had very carefully positioned the car to give myself maximum clearance in the front but with it jacked up the rear bumper would have been hit by the garage door and with the battery out I couldn't move it. DOH!) The catted X pipe was more difficult than I expected mainly because it is in 4 pieces and I could have used an extra set of hands. Good luck with your install, it is worth it in the long run!
-Wayne
Old Sep 16, 2010 | 09:26 AM
anteyeiabazele's Avatar
Hey can somone please enlighten me where do i place the red crank sensor/harness which is touching the header... if i turn on the car it will melt off! it is just hanging there out from the engine bay! Please share feedback!
Old Sep 16, 2010 | 11:12 AM
SONICBOOST's Avatar
I used jack stands for my Mac longtube install, probably a little easier than ramps when maneuvering in the car...
Jim74656
May 1, 2023 02:15 AM
drmag
Sep 1, 2015 03:47 PM
Good Times
Aug 29, 2015 10:18 AM
ClayP
Aug 3, 2015 09:00 PM
Vader99
Jul 19, 2015 08:19 PM
