gear whine driving me nuts
ever since i had my bmr LCAs, adj UCA and panhard put in, i am getting gear whine, mostly just from 60-80mph. i just did a 4 hour drive and its annoying. how can i get rid of this? its only on acceleration. i was told this is normal, but i want to get rid of it.
i had 4.10s put in a while before i did the rear suspension mods, the ford gears. never heard anything, even barely at all from the rear. am i going to just have to live with this because of the hard bushings?
Most of it is probably coming via the UCA. I just replaced my lower control ams and I have noticed a very slight increase in noise from the diff. I haven't done the UCA yet but I imagine I'll have the same issue. I did notice though that with just the LCA's my wheel hop is completely gone so I may not even bother with the UCA. You might want to try putting back in the stock UCA too see of that helps your noise issue.
Unless of course you need the adjustability. I am at stock height and don't plan to lower my car but your situation might be different.
I have the 4" D/S as well and my pinion angle is exactly where it should be.
I DID discover tonight my clutch blew up, sorta. It's not working well and there's significant damage to the bell housing, so I'd be carefull about launching at redline there as mine blew and I haven't abused the car at all.
I am amazed at how many people say adding an aftermarket shifter didn't add any noise to their interior. That, by far, is the biggest noise maker I own. The transfer of noise is pretty great under load with no dynomat installed. The UCA and LCAs have nothing on it.
Anyway, strange that the whining is that bad.
9/8/15 10:45 AM
