Gear Recommendations
Going to go to a taller gear for my hot rod now that it has a SC. I currently have 4.10s and looking for 3.73s or 3.55s. Have a choice between Motive, Ford Racing, Richmond and Pro 5.0. Any recommendations.
If you've kept your stock gears and still have the original inner bearing and shim on the pinion and kept record of your original side gear shim position it should be an easy reinstall.
So on a related note I am thinking of buying gears for my GT, it only has 14,500KMS on it (so less than 10,000 miles), do I need to buy a bearing/install kit for it?
Location: New Carlisle, Ohio (20 miles north of Dayton)
Hye Cowtown....my bet is that they do not come with those parts...that you will need to buy them in addition. And I never said it before but if I were you I would go strickly with the Ford gears.
Scott
Rando
8/25/21 11:12 AM
