Gear Recommendations
Old Mar 15, 2008 | 07:37 PM
btrokc's Avatar
Going to go to a taller gear for my hot rod now that it has a SC. I currently have 4.10s and looking for 3.73s or 3.55s. Have a choice between Motive, Ford Racing, Richmond and Pro 5.0. Any recommendations.
Old Mar 15, 2008 | 08:20 PM
SONICBOOST's Avatar
I don't think you can go wrong with ford racing, where are your stock gears?
Old Mar 15, 2008 | 11:27 PM
Lime GT's Avatar
If you've kept your stock gears and still have the original inner bearing and shim on the pinion and kept record of your original side gear shim position it should be an easy reinstall.
Old Mar 16, 2008 | 01:53 AM
Cowtown's Avatar
So on a related note I am thinking of buying gears for my GT, it only has 14,500KMS on it (so less than 10,000 miles), do I need to buy a bearing/install kit for it?
Old Mar 16, 2008 | 05:55 AM
70MACH1OWNER's Avatar
You do not need to buy new bearings but there is an assy kit that has a new crush sleeve and seal in it. You will need them.
Old Mar 16, 2008 | 07:03 AM
tom281's Avatar
+1 and I would stick with Ford Racing gears.
Old Mar 16, 2008 | 01:30 PM
Cowtown's Avatar
Thanks 70Mach1. Does the Ford Racing gears come wih those bits? I thought I saw on American Muscle that it did.
Old Mar 16, 2008 | 02:15 PM
Hye Cowtown....my bet is that they do not come with those parts...that you will need to buy them in addition. And I never said it before but if I were you I would go strickly with the Ford gears.
Scott
Old Mar 17, 2008 | 06:10 PM
Cowtown's Avatar
Oh fo' sho, wouldn't go for anything else, heard too many horror stories!
Old Mar 17, 2008 | 06:51 PM
Dougxox's Avatar
had dealer install my gears, covered under warranty
but it was a bit pricy.
Rando
Aug 25, 2021 11:12 AM
wallace
Mar 29, 2016 10:09 AM
GeoWett
Sep 30, 2015 06:40 AM
Jailbirdwatcher
Sep 25, 2015 06:39 AM
Grabber5.00
Sep 13, 2015 06:53 AM
