Gasket cinch?
Old Jul 28, 2007 | 01:12 PM
Croceye's Avatar
Gasket cinch?
I'm about to put in my intercooled Whipple and when reading the manual it calls out for "gasket cinch" before installing the gasket for the intake.
What is it and is it really necessary? I live in sweden and I've never seen the name before but most likely we do have something similar over here, I just dont really know what it is.
Every input is appreciated!
Old Jul 28, 2007 | 01:43 PM
70MACH1OWNER's Avatar
I'm no help. Never heard of that before. Good luck!!
Scott
Old Jul 28, 2007 | 02:21 PM
Croceye's Avatar
Scott
I'm not alone! Always something
Old Jul 28, 2007 | 03:18 PM
281GT's Avatar
Edelbrock Gasgacinch
Gasgacinch assures proper sealing of all gaskets used in a manifold installation. Also effective on water pump, oil pan and valve cover gaskets. Water and oil resistant. Allows easy gasket removal during parts disassembly.
Edelbrock Gasgacinch (4.0 oz.) #9300
This is from the Edlebrock website..
link below, scroll to the bottom of the page...
http://www.edelbrock.com/automotive_...allation.shtml
Old Jul 28, 2007 | 03:25 PM
Croceye's Avatar
Ok, I actually found that page but I still dont really know what it is. Is it something like this? http://www.gaelforcemarine.co.uk/Pro...oduct_id=20235
I'll probably use something like that if it looks necessary, I'll see when I take IC & SC apart. Theyre still in the box :-)
Old Jul 28, 2007 | 03:28 PM
281GT's Avatar
That will work. It's basically the same thing. Gasgacinch is a brand name of Edelbrock but just about any good quality sealer will work. I've used Permatex product like what you show above and I think it will work well for you.
Old Jul 28, 2007 | 03:57 PM
Croceye's Avatar
Ok, good to know.
Thanks a lot!
Old Jul 28, 2007 | 06:45 PM
RadBOSS's Avatar
Ok, good to know.
Thanks a lot!
Its a cure tacky adheasive that is brushed on. Very thin. Very easy to remove. Excellet for gasket or or machines surface that mater directly together. If you are familiar with contact (rubber) cement used for paper it is a lot like that but a different formulation. Just use a thin, brush on tacky kind of gaslet aheadsive if you can't get the real thing (was easy out in California, out here in Texas no one seems to know what it is either).
Beouch
Sep 16, 2015 06:14 PM
eastexsteve
Aug 17, 2015 12:07 PM
Torrence
Feb 23, 2006 07:20 PM
I8URVTEC
Dec 6, 2004 06:25 AM
EleanorsMine
Oct 6, 2004 04:16 PM
