FYI for the CHE K Member Brace with Torque limiters
if anyone is installing these parts, 2 little side notes. on the V8 manual it is the bolt below the starter, not above it.
Also the torque specs on the engine/tranny bolts says 85 ft/lbs in the instructions. DO NOT ATTEMPT 85 ft/lbs. you will snap the bolt off in the bellhousing like i did. Ford spec is 33 ft/lbs. it is a typo in the instructions.
