Fuel Injectors
Old Oct 11, 2010 | 02:11 PM
d_bone33's Avatar
Fuel Injectors
I have a question....if you do all these kind of mods like throttle bodies, and CAI and long tube headers, and all these air mods, shouldnt you put in bigger injectors to keep them not working as hard. I have a set of 39# injectors i figure maybe it would keep the stock ones from over working too hard. The problem is, i can hear my injectors they are so loud and i can hear them ticking when i lift my hood over the longtubes and exaust..and it just seems odd to me, like as if my injectors are working too hard
Old Oct 11, 2010 | 06:03 PM
Dread53's Avatar
You'll need to adjust for therm in the tune if you do change them, but it's not a bad idea if you're adding more power.
Old Oct 22, 2010 | 08:02 AM
J. Dub's Avatar
what size injectors are you thinkin about getting?
Old Oct 24, 2010 | 10:20 AM
ricksGT/CS's Avatar
Talking
Fuel Injectors-323725-r1-14-11a.jpg you have me thinking , ( what size are the stock ones and what size is good for a few mods ) I have the Ford Racing tune 91 gas and above only,and ,,,well just read below .......thanks for any reply
Old Oct 25, 2010 | 10:04 AM
Chip@TheDiabloShop.com's Avatar
NO, until you add something major as in forced induction or stroker engine you will not need any larger injectors.
The stock 3v injectors are 24lbs injectors and the PCM also makes changes to the fuel pressure to further compensate for fuel requirements. It can raise the fuel pressure to rates of 55psi and higher if the PCM determines so. A fuel injector is rated at 43psi of fuel pressure, so the more pressure the higher the rating. These injectors are more then enough that any 4.6 n/a combo with mild bolt ons and even cams and ported heads can handle.
On a side note, IF you have a combination that truly requires more fuel then the stock injectors can handle then I recommend upgrading the pump as well. Think about it, you're increasing the overall output of the injectors then you should alway increase the output of the pump feeding them.
Thanks, Chip
Old Oct 25, 2010 | 05:21 PM
ricksGT/CS's Avatar
Talking
Thanks, Chip
thanks for the reply,thats good to know,
NC14GT
Feb 20, 2023 09:42 AM
Sep 16, 2015 06:44 PM
Mrmiles1369
Sep 11, 2015 07:23 PM
Hristofor
1994-2004 V-6
Sep 11, 2015 12:05 PM
