FRPP x-pipe
Old Sep 20, 2006 | 09:10 PM
Fords4Ever's Avatar
FRPP x-pipe
Is anyone running the FRPP x-pipe with stock mufflers? I'm curious if it sounds/feels any different.
I was originally thinking SLP Loudmouths but now I'm considering FRPP x-pipe and FRPP Stingers. I'd probably do the x-pipe first cause it's cheap - around $100, then save funds for the axle-backs.
How do the FRPP Stingers compare to SLP for sound? I'm a little concerned that the SLPs might be too loud although I guess that's the point, right? Also I'm a little concerned about the SLP quality, I've seen a couple threads about SLPs wearing at the hangers.
Old Sep 20, 2006 | 10:59 PM
GRAYPNY's Avatar
I am currently runnng the FRPP X pipe and with stock mufflers. It sounds about the same except when you get on it. It comes alive at wot.
Old Sep 21, 2006 | 06:33 AM
bryanthomas's Avatar
EDIT: I found what I was looking for.
Old Sep 21, 2006 | 08:52 AM
34124231user's Avatar
I've got the FRPP X-pipe with Flowmasters. The X-pipe did change the sound at WOT, and a very subtle change at idle. At WOT it might be a little bit louder, but it does not sound as harsh- it's a more refined sound. I like it. At idle, IMHO, the Flow's sound less like a motor boat now.
Old Sep 21, 2006 | 11:19 AM
kampendmk's Avatar
x pipe
I installed frrp x pipe what a differents more power.I will see at the track tonite how much i gained .
Old Sep 21, 2006 | 12:11 PM
Original Sin's Avatar
Anyone out there yet had a chance to mate the FRP X pipe with the FRP (or Borla) stingers????? I've got the stingers now, love 'em (even the little bit of drone isn't so bad anymore, I just avoid that part of the rpm range at cruising speed) but I'm not in any hurry to amplify the drone if that's what the X pipe would do. Any thoughts???
Thanks - Mark
Old Sep 21, 2006 | 12:39 PM
SoFlaBoss's Avatar
Will FRPP X-Pipe fit onto V6 Y-Pipe?
Has anyone tried using specifically the FRPP x-pipe to convert a V6 to dual exhaust? Looks like it might work, at least I hope so.
Old Sep 21, 2006 | 06:39 PM
GRAYPNY's Avatar
Well I'll sell you my old H pipe if you want to make duals for your V6. PM me.
Old Sep 21, 2006 | 09:23 PM
Fords4Ever's Avatar
GRAYPNY, did the x-pipe cause any drone?
Did you install yourself? If so any issues to be aware of?
Old Sep 21, 2006 | 09:56 PM
GRAYPNY's Avatar
No drone and I installed it with the help of my neighbor. Pretty straight forward install.
Old Sep 22, 2006 | 04:55 AM
SoFlaBoss's Avatar
I also have an h-pipe sitting around, that I replaced with a Pypes O/R h-pipe, from my 05 GT. I just don't want to chop it up for the V6 and would rather use the FRPP x-pipe, if it will just bolt up after a couple cuts to the y-pipe. I guess I can measure my old h-pipe and see how it compares to the y-pipe.
Old Sep 22, 2006 | 09:14 AM
has anyone seen a dyno sheet on just the x pipe install?? What do they say the gains are supose to be from installing an x pipe?
Old Sep 22, 2006 | 11:50 AM
kampendmk's Avatar
at the track x pipe
I ran 8.657 et mph 81.58 with stock tires and gears with x pipe installed at irwindale last nite alot of wheel spin it`s a 1/8 mile track .60ft 1.944
Old Sep 22, 2006 | 06:18 PM
Fords4Ever's Avatar
Cool, Thanks! I wonder what kind of HP and torque increase this alone adds. Do you think it's 5HP or 5ft lbs of TQ?
Old Sep 22, 2006 | 06:37 PM
65sohc's Avatar
Several years ago a magazine compared h vs. x-pipes on a 4.6 2V Mustang. As I recall the x-pipe picked up a few, maybe 4-5hp, above ~4000 rpm and lost an equal amount below that speed.
Off-Topic Chatter
Sep 1, 2015 09:05 AM
blue.misty.pilot
Aug 21, 2015 10:03 AM
ustabawannab
Aug 5, 2015 08:32 PM
