FRPP Sway bar bushing help
Old Jan 6, 2013 | 09:27 AM
pebkac's Avatar
Need some help. Not willing to pay 150 for all the hardware for the bushing/straps mounts whatever you call them as I only need the two for the front of my car. Can someone take some measurements or let me know if they have used these before? I am sure they will work fine if I get the proper part. I believe they are the same thing provided in the first place.....
http://www.energysuspensionparts.com...r-Bushings.asp
Reason I can't measure myself is I bought one used and the mounts are not there, just the bushings.....
Old Jan 6, 2013 | 11:36 AM
70MACH1OWNER's Avatar
Looks to me like you buy them by the diameter of your swap bar. Dimension "A" Can't you measure the diameter of your swap bar?
Old Jan 6, 2013 | 04:01 PM
pebkac's Avatar
Yes, I can it is 35mm. I was looking at the size of the band more than the bushing as I am hoping to replace the band. The 35mm one has the following dimensions I would love to verify if someone could.
Width 1 3/8 The bushing opening is only 1 inch however so I may just have to use the bushing the way it comes....
Length 4 1/2
Height 2 1/4 which is minus the Zerk fitting on this image which is the one I think I should order. Just trying to be sure.....
I probably could have explained better in the first post.....
Old Jan 6, 2013 | 04:21 PM
pebkac's Avatar
Just found this one also for 35mm which might just be what I need. just realized base to center of bar could also be an issue. This one is 1 1/8 to cente and the other above is 3/4 to center.
Old Jan 6, 2013 | 04:28 PM
MARZ's Avatar
Swamp Donkey Aficionado
I have a set of extra sway bar "stirrups" in my garage if you want them. Pay for shipping and they're yours.
Old Jan 6, 2013 | 05:22 PM
pebkac's Avatar
Now that is what I am talking about!!!! Thanks for the "proper" name of them! Shipping to 27587. Will PM you exact address. Paypal? Will pay extra to make sure any fees are covered!
Old Jan 24, 2013 | 01:00 PM
pebkac's Avatar
Wish there was a reputation system on here as Mr. MARZ would have major +++ rep right now!!!!!! I am saved!!!
Thank you TMS and more so MARZ
Old Jan 25, 2013 | 03:28 PM
MARZ's Avatar
Any time, man! I'm glad I could help out!
Oh, and "stirrup" is just what I call them. I don't know if it's the correct terminology, but you know what I meant, right?
bones302
Oct 7, 2015 04:42 AM
RoushRS3
Sep 29, 2015 08:03 PM
Evil_Capri
Sep 25, 2015 12:56 PM
Sep 16, 2015 06:44 PM
robjh22
Sep 8, 2015 12:31 PM
