Follow up to my thread about grinding issues...
Old 4/30/08, 07:31 PM
  #41
metroplex's Avatar
FWIW, the past few days I had to drive the Stang in 30F-40F ambient and the 3650 felt fine using the Redline High Temp ATF. High Temp ATF has almost the same viscosity as pure MTL, but is a Mercon ATF. Redline also recommended that I use D4 ATF in my 3650.
Old 10/17/09, 06:45 AM
  #42
Indystang's Avatar
I have used Redline MTL in my 89 GT with excellent results. The only time I noticed any sluggishness was on below zero days. I also pumped out the rear differential and replaced it with their recommended lube. It made a big difference on the 89GT. Shifting was smooth as silk and it quieted down. I just ordered some MTL for my 2005 GT. I am going to give it a try and will report if I have any problems as it gets cold.
Old 10/17/09, 06:48 AM
  #43
metroplex's Avatar
I've been driving the Stang closer to freezing temps (32F) and the Redline High Temp ATF works flawlessly with my TR-3650. It shifts like it is 80F outside.
Old 10/17/09, 09:57 PM
  #44
BuzzyStang05's Avatar
I ran a 50/50 mix of MT-90 and D4 for about a year. I was great at first, but then it started getting stiff on me, even in the summer. Once I started bogging 1st all the time, I switched to Hi-Temp ATF like metroplex. That's what I'm going to stick with from now on.
jim010
6/24/24 04:23 PM
NC14GT
9/10/17 04:47 PM
Road_Runner
7/21/16 09:14 AM
10/2/15 01:00 PM
Quick Reply: Follow up to my thread about grinding issues...
