Flowmaster AT muffler leaking
I just reinstalled my ATs and I can't get rid of a gas leak on the driver's side muffler, where it connects to the mid-pipe.
I tried a few times already to re-arrange the muffler and the clamp, but there's still a small leak from the guidance notch. I'm thinking about using some high-temperature teflon tape or red silicone, but the passenger's side muffler is gastight just by using the provided clamp.
How did you guys install your aftermarket mufflers? Were the clamps enough, or did you use some kind of sealant between the pipes?
If this is a reinstall, are you reusing the Flowmaster AT clamps? These aren't the best clamps and many (including me) have had issues getting them tight enough. Hopefully your exhaust leak is not due to a crimped pipe (either over-axle or AT inlet) from your previous install. Visually inspect the AT clamps for any stress/wear (on threads or nut). If they look OK, I'd suggest you apply some anti-seize lubricant to the threads only. I've heard that failure to apply lubricant can cause the nuts to seize on clamps and potentially damage threads (per a Z06 exhaust website). They also recommend to thoroughly clean hands after use.. and anti-seize lubricant will tarnish SS parts. Here's another important point I pulled off the site: "...clamps should be tightened using a properly calibrated Torque Wrench. Using an air impact gun will damage the clamp and reduce its ability to effectively seal the joint". Hope this helps.
If you're trying to get it to work with the stock clamps, make sure to straddle the notch with both sides of the flowmaster clamp, one side of the clamp will be just on the very edge of the flowmaster pipe. This tends to fix up that issue pretty quick.
That's the way I have them but they both leak at the alignment stud.
Sounds like you need some new clamps then. My friend just installed a set and the left one we thought we had good and tight. One trip and it came apparent it wasn't. I checked it when he was in the car the next day and sure enough there was a lot of play at the joint. He got under there last night and cranked it down and it cleared up.
I'm surprised it's leaking at the stud though, there is a lot of pipe overlap there, but hey if it's leaking it's leaking.
Why don't you look at my previous post a little better, it says I don't want to buy "any more" clamps, I got the U-Bolts like everyone suggested but I thought I would try to torque them first just in case I didn't have them tight enough like a few other members said. Because once I put the U-bolts on I know it will be hard the get the mufflers back off.
The leaks are easy to see/find. Start the car up early in the morning when it's cooler, let idle for a few minutes, then crawl under the car and look at the connection. You'll see steam coming from the connection and condensation building up in the area as well. You can ever "cuff" you're hand around the exhaust opening to exaggerate the condition, or have someone rev the engine while you're under there... which can be sacary as you can picture the rear tire going over your head like Phil from the Sopranos... crunch!
9/10/15 12:44 PM
