Factory air intake Question
Any one have their intake tube off? I just got my 05 GT back from dealer . The inside plastic re-inforcement? broke and went into the cylnder causing the valve to stick and then the rocker came off. The peice of plasic fits neer the MAS. Any one have some photos of the inside of the intake tube from the MAS side? Dealer tech thinks it is aftermarket peice lol
The dealer tech is either an idiot or trying to get you to pay for what should be a warranty-covered repair.
Maybe it was a part of the hydrocarbon trap (OEM on early 2005 MY cars) that broke off and was sucked into the throttle body and maybe even past it. Do you know if your car came with a HC trap? Mine did and removing it was the first thing I did when I got home after picking the car up.
There is a hard reinforcement at the throttle body side of the air inlet tube (where it makes a cone). Some 05 GTs had a cardboard-like insert in the inlet tube for emissions, but this was later removed for 06-up models.
This is hard plastic. I would like to get a photo of the MAS side . Thanks for the HC trap though.
Would this device happen to be what you're referring to ? If it is this device is know as an intake pulsation tank that appears in some 05 Stangs with automatic transmissions only
Part #s?
Here is what is on the plastic part
MAD03-0336
PA66-GF+M 12
If someone has the intake tube off this would be at the MAS end. Unless its broken like mine you can't see the part #s either. I just need a photo. Thanks
MAD03-0336
PA66-GF+M 12
AKBOSSMAN, can you provide an exact motorcraft part # and a pic ? if you're not sure how to post pic's on here, just let me know and I'll walk you through step by step. I also looked at my stock inlet tube and cannot locate this oval shaped device you're referring to on either the MAF or throttle body sides unless your referring to the reducer tube which attaches to a smaller rubber hose that plugs into the valve cover on the driver's side but I don't think that's the right part either because it's not oval shaped.
If you try to squeeze the oval part of the tube near the Throttle Body, there is a hard support/object inside the tube most likely there to prevent that part of the tube from collapsing.
Ecoboost
Jul 25, 2015 06:32 PM
