Exhaust bolt keeps coming loose
Old Jun 29, 2005 | 07:39 PM
max2000jp's Avatar
I installed an Off road X-pipe a couple of weeks ago and the one nut on the passenger side keeps coming loose. I tighten it up pretty good, but my friend told me not to torque it down too much because you might pull the stud thru. I was thinking of using some threadlocker, is this my best option?
Old Jun 29, 2005 | 07:40 PM
169stang's Avatar
Are you talking about clamps? If so, get a hold of a diesel exhaust clamp. You can't break one!
Old Jun 29, 2005 | 07:41 PM
Mongoose's Avatar
Use two nuts.
Old Jun 29, 2005 | 07:43 PM
max2000jp's Avatar
I am referring to the lower bolt on the stock exhaust manifold flange. It keeps coming loose, which I feel is due to vibration. It is currently leaking and making a minor rattling noise.
Old Jun 29, 2005 | 07:44 PM
max2000jp's Avatar
Originally posted by Mongoose@June 29, 2005, 8:44 PM
Use two nuts.
What about locking nuts???
169stang's Avatar
oh. If you do go with thread lock, make sure to get the red, high temp kind.
Old Jun 29, 2005 | 08:15 PM
Mongoose's Avatar
The very last thing you want to do is use lock tight on exhaust manifold bolts.
They will break off for sure when you try to remove them. Are you sure the bolt is not too long. Sometimes they are and you need to shorten them a few threads. I use to use stainless bolts with anti-seze an all exhaust applications.
Old Jun 29, 2005 | 08:23 PM
169stang's Avatar
I was unsure about using theadlock in this application. What Bill says makes sense. It most likely is too long if you can't keep it tight. Some exhaust bolts use washer's as well.
Old Jun 29, 2005 | 10:42 PM
max2000jp's Avatar
Bill it is the stock bolt on the OEM manifolds. I just removed both nuts during the install and then bolted them back up. I might try a "locking" washer and some threadlocker. You can unbolt the the threadlocker I bought with hand tools it says.
Old Jun 30, 2005 | 11:53 AM
Mongoose's Avatar
You have me totally confused. One sentence you say bolts the other you say nuts. Which is it? I have not looked at mine so I do not have a clue which we have. It is your car so do what you like about the thread lock. A word to the wise should be sufficient.
Old Jun 30, 2005 | 12:41 PM
169stang's Avatar
It really makes sense not to use thread lock. I believe they are bolt or studs. You should be able to tighten it up. If you can't, I would tend to think they are too long.
Old Jun 30, 2005 | 12:53 PM
max2000jp's Avatar
Sorry I might not be coherent in my description. The nut is coming loose off of the stock bolt/stud on the header flange, which is causing a leak. I talked to a friend of mine whom builds race cars and he stated that a locking nut and threadlocker should do it. The threadlocker I bought isn't permanent.
Old Jun 30, 2005 | 01:09 PM
cop on my back's Avatar
I don't think Loctite will work on exhaust bolts. Loctite is only good to 300 F so it wil become liquid again defeating the threadlocking ability. You should try a stove (crimped) nut.
Old Jul 5, 2005 | 12:28 PM
smerrill's Avatar
Used blue Loctite on Harleys for years and works fine. Wouldnt worry with using it in your application either.
Old Jul 5, 2005 | 03:01 PM
169stang's Avatar
I thought those nuts were fixed on the bolt? There is some red threadlocker that is heat resistant. You'll get it on there tight before long!
Ecostang
Nov 3, 2022 08:50 PM
gobraphil
Sep 25, 2015 12:43 PM
00StangVert
1994-2004 V-6
Sep 11, 2015 12:08 PM
tony2014mustang
Aug 9, 2015 03:04 PM
ClayP
Aug 3, 2015 09:00 PM
