Engine temperature
Old Nov 19, 2005 | 01:20 PM
tnmustang's Avatar
How is everyone's car running temperature wise. My temp gauge is sitting mid way between center and the top blue mark of the normal range. Seems a little warm. Yesterday in traffic it almost got to the last blue mark and didn't go down once I got out of traffic. It was only 50 degrees outside. Every other Ford I've owned has ran to the cold side.
Old Nov 19, 2005 | 02:36 PM
Boltzman's Avatar
mines a little past half to the warm side
Old Nov 19, 2005 | 03:04 PM
grrr428's Avatar
About half way in 80 degree weather.....or any outside temp.
Old Nov 19, 2005 | 04:41 PM
don_w's Avatar
Mine never makes it to the halfway point... always slightly under.
Old Nov 19, 2005 | 05:26 PM
94tbird's Avatar
same here always under half
Old Nov 21, 2005 | 07:45 AM
MTAS's Avatar
Seeing as how the factory temp gauge is SO accurate at giving us real numbers , here are the numbers I get with the high speed fan set to kick on at 190* and shut off at 180*, via Predator. The Autometer coolant temp gauge's sensor is in the driver's side of the block, just below the exhaust manifold. Once it's warmed up, the gauge reads a constant 193* to 195*. I'm still waiting on an answer from Ford as to why the temp isn't closer to 180* (especially seeing as how the car came with a 180* thermostat from the factory), and what I can do lower the temp.
Road_Runner
Sep 2, 2024 04:46 PM
trackpack13gt
Oct 2, 2015 08:20 PM
Evil_Capri
Sep 11, 2015 08:39 AM
