Endlinks comeing loose again v. use locktite?
Old Jan 13, 2007 | 08:27 PM
06GTwJUICE's Avatar
My endlinks sound like they are loose again just from daily driving. I'm going to tighten them in the morning but was wondering if anyone used locktite for them?
The stock ones ahve the second bolt that keeps it from coming apart completely and could pose a problem if you have to undo the bolt one day the small one may strip or round off trying to get the larger nut off.??
I was considering aftermarket GMS or Steeda endlinnks and then puting locktite on them since they are composed of single nuts on each end making locktite no so troublesome.
I hate having to tighten these every few months, and since i never change the sway bar settings... it seems logical to locktite it.
thanks
jake
Old Jan 14, 2007 | 12:50 AM
Mongoose's Avatar
If you do use the locktite use the blue.
Old Jan 14, 2007 | 07:44 AM
05GT-O.C.D.'s Avatar
I lust for a M24
Loc-tite is your friend. Let your friend help you out.
Old Jan 14, 2007 | 08:13 AM
Import-Slaya's Avatar
Did you use new locknuts when you installed? I don't have the part number handy, but your dealer can sell them to you (search the forum--I think the part number has been listed before). The ones from the factory are designed for one time use, which is why so many of us have had loosening problems.
Old Jan 14, 2007 | 08:26 AM
thump_rrr's Avatar
Are you torquing them to factory spec?
I have the Steeda Competition Endlinks and there is absolutely no noise from them.
Yes they male a street version also. I would have suggested them if there was any noise coming from mine. The rod ends are easily replaceable on the competition ones.
Old Jan 14, 2007 | 08:37 AM
06GTwJUICE's Avatar
I didn't replace them so i could investigate getting a new set from the dealer. I didn't know they were one time use. As I never really change of mess with suspension it would make sense to either get new locknuts or get new ones and locktite them anyway.
I think the only thing i would or might change is the settings on the dampers... i love the way the car handles on the middle setting on the sway bar so that wont change again.
thanks.
getting new locknuts and getting out the locktite....
jake
Old Jan 14, 2007 | 03:21 PM
thanks.
jake
I hear ya. I don't think any of us expected reusing them to be a problem, but it has turned into a common issue for all of us who installed new struts.
FWIW, I finally got mine to stay tight by hitting them with an impact wrench. It's been a few months without a problem. If they come loose, though, I'll be picking up a few sets of the locknuts from the dealer.
Old Jan 14, 2007 | 03:38 PM
06GTwJUICE's Avatar
done... tightened as hard as I could get them with blue locktite...
The right one (passenger side) was loose on top and bottom. I dont suspect they will come loose again.
Old Jan 16, 2007 | 08:08 AM
GTRacerX's Avatar
Talking Steeda New Suspension Parts !!
Heavy Duty Upper Strut Mounts & Front Competition / Street Endlink Kit
My next buy !!
Old Jan 16, 2007 | 11:37 AM
metroplex's Avatar
How much torque did you use? Torque it to the factory spec.
Old May 27, 2007 | 11:12 AM
YaoNYC's Avatar
hi everyone,
anyone know where i can find info on factory torque specification for front and rear sway bar endlinks?
thanks!
Old May 27, 2007 | 09:23 PM
05BlackGT's Avatar
Here...85ftlbs front and rear.
Old May 28, 2007 | 08:19 AM
kevinb120's Avatar
Originally Posted by YaoNYC
hi everyone,
thanks!
In TacoBill's hotlinks he has all the front and rear specs in his steeda springs threads.
Old May 28, 2007 | 10:29 AM
ford4v429's Avatar
legacy Tms Member
if they come loose a first time, any chance movement caused a 'ridge' around the hole from the bolt wallowing it out a little? wonder if hitting it with a flat file(and some paint) might help prevent recurring?
ricky1728
Feb 11, 2016 07:25 PM
oneeyedgiant
Nov 16, 2015 12:23 PM
Sep 30, 2015 07:02 PM
