Dynojet Numbers
I finally got to get on the Dyno.It was a Dynojet.There is two sets of numbers one is SAE and the other STD.
On the STD= Max Power =292.83 Max Torque=313.69
On the SAE= Max Power=284.92 Max Torque=305.22
Conditions were 60.22F /29.67 in-Hg,Humiditity;51%
Another photo.
Originally posted by Blazing Saddles@May 25, 2005, 5:36 PM
Those are good #'s. That looks like Performance Dyno in Concord. Did you have to adjust your A/F ratio.
What is the diference from SAE and STD?
I just did my first dyno last night, I did it on a Mustang Dynometer and my HP was 245 and my FT-LBS was 254 @ 6000 RPM, does that sound right?? Anyone?
Originally posted by Lowe!@May 25, 2005, 9:40 PM
WOW, I hope you copied and pasted that from somewhere!?!
If you have an automatic that sounds very realistic. Almost identical to mine stock. Depressing for us automatic owners. What's worse is the automatic looses between 18-22% of the flywheel HP. In other words for an automatic vehicle to produce the same RWHP as a manual vehicle flywheel HP has to be significantly higher. Ask me I know!! I have done the same mods on my automatic that others have done on manual transmission vehicles and RWHP is substantially lower.
How do you increase the a/f I have installed the Mac cai and predator 91 tune however I get an engine light and the code states lean bank 1& 2 I tried to richen it up with tuner but does not seem to work, I had it set on the dyno and the operator said the a/f was set, but half way home the light came on.
PonyMuscletang13
9/29/15 09:40 AM
