Dynojet Numbers
Old May 25, 2005 | 05:25 PM
mikem's Avatar
I finally got to get on the Dyno.It was a Dynojet.There is two sets of numbers one is SAE and the other STD.
On the STD= Max Power =292.83 Max Torque=313.69
On the SAE= Max Power=284.92 Max Torque=305.22
Conditions were 60.22F /29.67 in-Hg,Humiditity;51%
Old May 25, 2005 | 05:26 PM
mikem's Avatar
Another photo.
Old May 25, 2005 | 06:38 PM
mikem's Avatar
Originally posted by Blazing Saddles@May 25, 2005, 5:36 PM
Those are good #'s. That looks like Performance Dyno in Concord. Did you have to adjust your A/F ratio.
Yes, It was Performance Dyno.We did have to adjust the fuel.I was running lean so we added fuel and the numbers came right up.Car also felt very strong on the ride home.I had the day off today, So I called Pete and he said sure,come right up.So I jumped in the car and drove up.He remembers you and a couple of other 05,s.Was not happy about Driving the car in the rain
What is the diference from SAE and STD?
Old May 25, 2005 | 07:22 PM
Mongoose's Avatar
George thanks for the very informative reply.
Old May 25, 2005 | 07:37 PM
Lowe!'s Avatar
WOW, I hope you copied and pasted that from somewhere!?!
Old May 26, 2005 | 07:30 AM
MaverickMLFD371's Avatar
I just did my first dyno last night, I did it on a Mustang Dynometer and my HP was 245 and my FT-LBS was 254 @ 6000 RPM, does that sound right?? Anyone?
Old May 26, 2005 | 09:26 AM
porsche's Avatar
sounds like a stock auto.
Old May 26, 2005 | 05:11 PM
nbk13nw's Avatar
Question
I would be scared if he wrote that from memory!
Old May 26, 2005 | 05:19 PM
tmcolegr's Avatar
If you have an automatic that sounds very realistic. Almost identical to mine stock. Depressing for us automatic owners. What's worse is the automatic looses between 18-22% of the flywheel HP. In other words for an automatic vehicle to produce the same RWHP as a manual vehicle flywheel HP has to be significantly higher. Ask me I know!! I have done the same mods on my automatic that others have done on manual transmission vehicles and RWHP is substantially lower.
Old May 26, 2005 | 08:27 PM
elvism's Avatar
mustang dyno is always lower number.
Old May 27, 2005 | 06:24 AM
mines a manual, not auto.....
Old May 27, 2005 | 10:30 PM
cfr865's Avatar
How do you increase the a/f I have installed the Mac cai and predator 91 tune however I get an engine light and the code states lean bank 1& 2 I tried to richen it up with tuner but does not seem to work, I had it set on the dyno and the operator said the a/f was set, but half way home the light came on.
Old May 28, 2005 | 08:36 PM
mikem's Avatar
On your predator go to the tune your running and modify tune.Then go to W.O.F and adjust it more rich.Make a big adjustment and see how it goes.If all else fails leave car running and check for vacuum leak.
Road_Runner
Sep 2, 2024 04:46 PM
PonyMuscletang13
Sep 29, 2015 09:40 AM
TerryD
Sep 28, 2015 11:48 AM
UOP Shadow
Sep 27, 2015 07:24 AM
MustangGTCS13
Sep 17, 2015 07:38 AM
