Drag Radial tire pressure
Old May 30, 2006 | 02:39 PM
bigaloz's Avatar
I am waiting for my Mickey Thompson drag radials to get here, and I was just wondering what tire pressure should I start with?
Old May 30, 2006 | 03:37 PM
don_w's Avatar
I suggest following Mickey Thompson's guidelines: http://www.mickeythompsontires.com/tech_pressure.html
And pay special attention to this note on that link.
Note: Many racers feel that "Less is Better" with regard to air pressure. This is not always the case. While there are exceptions to every rule, we have found higher pressure generally works best with Mickey Thompson Tires. Not only do the higher pressures lead to quicker times, but they also contribute to a safer, more stable ride at the finish line.
Old May 31, 2006 | 06:06 AM
bigaloz's Avatar
Thanks Don
Old May 31, 2006 | 09:09 AM
My Blue Heaven's Avatar
Thanks again Don, I had looked at that before but completely forgot about it. Have been running 22/24 in my M/T dr. Next time I'm out I'll drop it to 16 and see how it goes.
chris
Old May 31, 2006 | 10:49 AM
don_w's Avatar
chris
I say drop it slow. When I first started running the DRs, I started at 20psi. Then I dropped it in 1psi increments, eventually settling on 17psi. That was with a short 26" tire (275/40-17) and 4.10s. When I get back to the track, I'll have 28" DRs (275/60-15) with a lot more sidewall, so I'll start at 20psi again. I wouldn't be surprised if 20psi works just fine for me.
Old Jun 1, 2006 | 07:18 AM
stkdidy's Avatar
i have 275/40/17 nitto 555r's...they are a 27in tire IIRC. 810 rotations per mile give or take 5, i believe?
Old Jun 1, 2006 | 09:36 AM
don_w's Avatar
275/40-17s are probably closer to 26" dia.
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
NC14GT
Sep 10, 2017 04:47 PM
trackpack13gt
Jul 25, 2017 05:29 PM
samjluck
Oct 26, 2015 05:17 PM
