Door Handles nor seating cleanly?
Old Jul 29, 2007 | 02:20 PM
Ugabulldog83's Avatar
Folks,
Has anyone had a problem when they open their Mustang's car doors or shut them?, that they don't lay flat or seat cleanly? What is the fix, dealer or ad-hoc? Its annoying but not a safety issue, the doors are shut. Help?
R/Mike
Old Jul 29, 2007 | 04:14 PM
JRay05stang's Avatar
you need to go to the warranty section my friend... there is a tsb fix for this problem I just had mine fixed as well
Old Jul 29, 2007 | 05:30 PM
anthony05gt's Avatar
The actual door handle itself has a spring that's molded right into the plastic on the back side of the handle. The spring can't be changed, the handle must be replaced which means the new handle has to be painted to match. My dealer gave me the part after they had it painted. The interior panel has to come off and the glass must be removed to access the bolts to the handle. It's not too bad of a job, but if you're not a mechanic I suggest a warranty visit.
Old Jul 29, 2007 | 11:43 PM
STANG_IT's Avatar
It happened to me a while back on both sides. Had them fixed under warranty and now it's happening again to my driver's side.
Old Jul 30, 2007 | 05:10 AM
Hatchman's Avatar
I had both replaced. This is VERY common. But it's a quick fix at the dealer... after I waited two months for them on national back order and to have them painted.
Old Jul 31, 2007 | 12:29 PM
LimeGT's Avatar
Do some searches and check out this thread if you are mechanically inclined and afraid, as I am, to let the dealer touch your car. It only applies to a specific failure, but it has worked for me since March of last year. Good luck.
http://forums.bradbarnett.net/showthread.php?t=44694
kponypower
Jun 17, 2020 07:17 AM
NC14GT
Sep 10, 2017 04:47 PM
GeoWett
Sep 30, 2015 06:40 AM
Ray11
Sep 25, 2015 12:43 PM
