Define this noise
Old Oct 26, 2006 | 10:07 PM
eci's Avatar
eci
Define this noise
Low RPM, say 1300 or so in 2nd gear, you give it gas and there is a horrible rattle..until the engine builds torque and the RPM's raise. It sounds like you are dragging something on the ground.
Old Oct 26, 2006 | 10:44 PM
RPM's Avatar
RPM
Muffler bearings are shot. Time to take it in.
Old Oct 26, 2006 | 10:45 PM
eci's Avatar
eci
Haha eat it
Old Oct 27, 2006 | 05:36 AM
theedge67's Avatar
Sounds like spark knock, but there shouldn't be any spark knock in a brand new car, unless you have mods you haven't listed. Maybe spark knock at less than 1000rpm, but not 1300.
Old Oct 27, 2006 | 06:49 AM
OKCMustangGT's Avatar
Where is the noise coming from can you tell??
Any aftermarket parts, exhaust, etc. ??
Old Oct 27, 2006 | 09:11 AM
eci's Avatar
eci
Mods: Bamachips 91 Race tune, C&L CAI, Corsa exhaust. I'm wqondering if it's just transmission lugging. I've jst never heard that this loud.
Old Oct 27, 2006 | 09:38 AM
mitch e's Avatar
sounds to me like your lugging it and you need to put it in first gear. mitch e
Old Oct 27, 2006 | 09:55 AM
RKNMACH's Avatar
I agree with the "lugging". I spend most of my drive to and from work in traffic (DC) and if I don't downshift low enough it will lug a little bit.
Old Oct 27, 2006 | 10:02 AM
BuzzyStang05's Avatar
H-pipe hanger rattle? That's what caused mine...
Old Oct 27, 2006 | 10:07 AM
24FAN's Avatar
Maybe your dragging something on the ground.
Old Oct 27, 2006 | 10:44 AM
06GTwJUICE's Avatar
I pull out IN second gear sometimes, since i'm in traffic. It just keeps me from having to shift when i'll end up stopping again in a couple yards anyway... and mine "lugs" when pulling out...
look under your car and make sure there's not a honda stuck to the underside of your car.... you could be dragging on of those...
Old Oct 28, 2006 | 01:29 AM
JGT's Avatar
JGT
If the sound seems to be coming from behind the center console, this is the exact problem I had. Awful rattle at about 1200-1300 RPMS then it disappeared.
Turns out it was related to a TSB, don't remember the number, but look for the one about rattle behind center console. Two clamps and I haven't heard the sound since.
Old Oct 28, 2006 | 09:25 AM
ski's Avatar
ski
Old Oct 30, 2006 | 06:42 AM
bwilder10h's Avatar
Interesting, can you elaborate please....
Old Oct 30, 2006 | 12:54 PM
There's a whole TSB about it:
http://bradbarnett.net/mustangs/gala...sb06_04_01.pdf
I tried the clamps, actually bought some t-bolt clamps from Summit rather than worm clamps...and it still didn't fix it entirely, but better anyways. Then when I put in my new street legal x-pipe, it went away completely.
My stock H-pipe didn't fit real well into the crossmember hangars in the first place. They were not centered in the rubber grommet. Another user here posted that their dealer ended up loosening the entire exhaust system from headers to mufflers and repositioned everything, problem solved.
Check to see if your hangars are in the center of the rubber and not pulling it to one side. If they're tweaked off to one side, that could be it.
Rando
Aug 25, 2021 11:12 AM
JonathonK
Which is Better
Nov 17, 2017 12:02 PM
Mr. V
Dec 24, 2016 02:57 PM
ricky1728
Feb 11, 2016 07:25 PM
Rando
Sep 30, 2015 12:28 PM
