Defective Boost Pump
Old May 22, 2007 | 07:43 PM
cfr865's Avatar
Anybody have a Keene Bell bap go bad ? If one did could it cause one of the connections that's arrow clamped to blow off. I was driveing Sat. getting on it pretty hard when the engine suddenly quit, had to be towed home. I discovered one of the connections had come apart, put it back on, the car still would not start, I then checked the fuse in the bap, it looked okay, I took it out and the car started right up. It would not idle but ran okay as long as you kept your foot on the gas. Put the fuse back in, it started but ran very rich bad and rich.. Let it sit for an hour and tried again would not start, took fuse out ran as before . It also threw a code P0191 fuel rail pressure sensor circuit/ performance, this was when the fuse was in the bap. Any ideas ?
Old May 22, 2007 | 08:11 PM
tom281's Avatar
Wow that's crazy...... hopefully not a sign of things to come from these BAPs.
Old May 22, 2007 | 08:30 PM
cfr865's Avatar
I know the first one Dave put in when he did the install was bad, he said it was the first time. I'm 99% sure this one went bad also. I also found the connection came off near the oil filter on the s/c, you don't thnk the bap going bad could have blown this off also ? O r did I have two seperate problems. I f it is in fact the bap again I'm switching to the GT500 fuel pump, I won't trust the bap again. I want to take it on vacation this Sept. to the smokey mts. don't want to get stranded !
Old May 22, 2007 | 08:33 PM
tom281's Avatar
I don't think the BAP would cause your connection to fail at the oil filter. Eitherway, hopefully you'll be able to absolutely positively confirm the BAP is bad or not. If it is, I would upgrade to the GT500 pumps or maybe the Ford GT pumps. I'm thinking about that myself too.
Old May 22, 2007 | 08:44 PM
Bullitt995's Avatar
My boost-a-pump doesn't do anything. Turn the **** all the way off and all the way on and it won't do anything either way.
Old May 24, 2007 | 12:19 PM
MaverickMLFD371's Avatar
thats why I never trusted boost a pump on KBs
redrock35
05-09 Exterior Modifications
Jul 31, 2016 08:50 PM
09-gt/cs
Oct 15, 2015 10:03 AM
Sep 16, 2015 06:44 PM
Beouch
Sep 16, 2015 06:14 PM
retiredf5
Ecoboost
Jul 21, 2015 05:54 PM
