Crankshaft position sensor wire
The crank position sensor is under the AC compressor on the front passenger side of the engine. The ECU is mounted next to the engine next to the passengers side of the engine, so I would suspect the wire from the crank sensor is a short wire in the harness up the side of the engine and across to the ECU.
It is actually fairly easy to get to the crank sensor connector on our cars, but you will have to get the nose up enough to get under it.
Dude just get a Raptor shift light, it ties right into the coil on passenger side, closest to the fire wall. Then power, and ground......... three total connections. Just my 2 cents.
