Crankshaft position sensor wire
Old Sep 10, 2008 | 03:14 PM
Chilliwack 42's Avatar
Im trying to install a shift light, I plan on picking up a ford racing tach adapter, anyone know where the crankshaft position sensor wire is located?
Old Sep 10, 2008 | 05:35 PM
RRRoamer's Avatar
The crank position sensor is under the AC compressor on the front passenger side of the engine. The ECU is mounted next to the engine next to the passengers side of the engine, so I would suspect the wire from the crank sensor is a short wire in the harness up the side of the engine and across to the ECU.
It is actually fairly easy to get to the crank sensor connector on our cars, but you will have to get the nose up enough to get under it.
Old Sep 10, 2008 | 06:12 PM
tom281's Avatar
Dude just get a Raptor shift light, it ties right into the coil on passenger side, closest to the fire wall. Then power, and ground......... three total connections. Just my 2 cents.
Old Sep 10, 2008 | 07:26 PM
Robbieg's Avatar
+1...Raptor is awesome and simple, I love mine.
May 3, 2026 05:42 AM
trackpack13gt
Jul 25, 2017 05:29 PM
RCooke08GT
Feb 19, 2017 03:03 AM
