Crane Z Cams
Crane Z Cams
Anybody have any experience with cranes new z cams. i am interested in there stage4 cams. well hear are the specs for all stages..
http://www.rpmoutlet.com/05gttran.htm
does anybody have any sounds clips of the stage4 cams. i am definitely in it for the performance but i would also love the nice lope sound to the exhaust? is this a good or poor choice for cams? any info would be great, thanks.
I would stay as far away from Crane products as possible. I as well as many other people have had problems with their quality control. I had a couple sets of their rocker arms and adjusters on my mopar fail in 1000 miles on my mopar. A ton of other people have had, and are still having the problem.
Cranes quality control program is simple. Ignore the defects that customers complain about, and everything passes.
To be honest, comp is about the only cam grinder I would go near at this point.
I haven't had any problems using Crane products. I have used their stud rockers as well as their shaft rockers and cams with no problems.
You can also look at Crower
http://www.crower.com/cat/domestic/f...amshafts.shtml
Crane cams can cause piston to valve contact. Read the subsection in their cam guide.
http://www.cranecams.com/pdf/PP1105B.pdf
From the information I have been able to gather Comp or Crower cams will be the choice for my '05. I like the stage 2 selection because of the jump up in mid-range torque but most of the shops I have spoken to say go w/ stage 3. Stages one and two are only there for stage 3. Comp and Crower stage 2's have very similar numbers/set-up.
I am still saving so I have some more time to make up my mind.
