Cool Stuff for your Stang from RPM Outlet
Some new stuff for the 05/06 Mustangs at RPM Outlet. (at least I've never seen them).
05 GT Mac Pro Chamber and SLP Powerflow/Loudmouth exhaust
Mac Pro Chambers that bolt to the stock cats, combine with SLP's Powerflow or Loudmouth exhaust. Go to the bottom of the page.
O2 Sensor Simulators and extenders
Must for long tube headers. Seen these just thought I'd post them.
Hurst Shifter for 05/06 Stangs
Put a Hurst in your Stang!!!!
Electric Water Pump
Meziere Electric Water Pump.
Electric Water Pump
Originally posted by ZwerRacing@May 30, 2005, 10:32 AM
those pumps make good hp in some article i noticed that they picked up like 10 hp or so.
A solid 11.2 RWHP according to RPM Outlet.
Anybody dyno'd the difference with the water pump?
Sounds like a good deal to me.
And, anybody try the Hurst Shifter? I missed the heck out of 3rd gear the other day, it was like the shifter locked me out of it. Pissed me off! Gotta get the Hurst, if it works.
http://www.rpmoutlet.com/05gt.htm.
The motoblue pulley package looks cool also.
That electric water pump looks interesting.
However, the stock mechanical one is less likely to fail IMO.
You're also substituting electrical "drag" for mechanical drag which might be an issue if you have underdrive pulleys.
Electric Water Pump
Electric Water Pump
RPM outlet is advertising your shifter for the 2005 mustang GT. http://www.rpmoutlet.com/05gthur.htm Do you have more info on the kit? -is the chrome shift stick the embossed one -what color is the *** -will you offer a hurst shift boot for it? Thanks in advance.
Solution:
We have not released the 05 shifter yet. It will not be available until later this year. Thank you
Originally posted by tech@May 31, 2005, 12:28 PM
I wouldn't get too worked up over the Hurst Shifter yet (because I did). This is the question and reply I recieved from Hurst:
Solution:
Solution:
I seen dyno numbers of the electric water pump somewhere, sorry don't remember where but it was worth 6hp.
I ordered the pro chamber that bolts up to stock cats and slp loudmouths from RPM outlet.
I'll post sound clips when I get it in and put on.
Originally posted by whiteboyslo@May 31, 2005, 1:41 PM
site says easy 30 minute install for the Hurst. that doesn't sound right. doesn't the Steeda and other shifters need you to get underneath the car? is this one any different?
Mike
Mike
I don't think it would take long to swicth out the shifter. I installed the steeda bushings. It took no time at all, and I did not remove the driveshaft, ut I did remove the shifter. Basically, there are two bolts and two nuts to remove from the shifter, and comes off the car. Then the four for the driveshaft. Drop those, swap the shifter, and replace.
