check engine light / longtube headers
Old Sep 2, 2008 | 07:37 PM
oneunderone's Avatar
okay so i installed mac longtube headers on my car and now the check engine light is on pulled the codes and here is what came up
PO133 ox s cir
po153 ox s cir
SLW RESP 1 S1
SLW RESP 2 S1
any suggestions to help me solve this?
Old Sep 2, 2008 | 07:43 PM
mustanglouie's Avatar
yeah post up more videos of your exhaust lol. Sorry I do not know the answer to your question.
Old Sep 2, 2008 | 07:58 PM
Do you have a tuner? Did you get a new tune to turn off the rear O2 sensors from someone like Brenspeed, Bamachips, or Tillman?
Old Sep 2, 2008 | 08:01 PM
aircare84's Avatar
You'll need to add some delay into the forward O2 sensor circuits. You'll have to have one of the aftermarket tuners dial this in for you.
Not sure on the MAC headers, but on my OBX's the fwd O2 sensors are in the header collectors & I had to install extenders.
Brent told me that the O2 sensors will run cooler than factory in the collectors. I still get an occasional P0153 & am working with Brent to get an acceptable delay in the circuit without throwing other codes.
It's only an annoyance issue & has not affected the performance at all.
The other option is to have the CEL turned off.
Old Sep 2, 2008 | 08:02 PM
officespace56's Avatar
Correct me if I am wrong here but couldn't he get some MIL eliminators?
Old Sep 2, 2008 | 09:35 PM
08VistablueGT's Avatar
Yup, simple, need to have the tune changed due to the repositioning of the forward stream o2's. Some aftermarket longtube headers make sure to keep the bungs at the same length as factory, however other's do not. Good luck!
Old Sep 2, 2008 | 09:44 PM
05fordgt's Avatar
I get his code every so often and like the others its a small annoyance. I just clear it and move on. I have found a happy medium though. When I start the car, I let it run for a few minutes or so, and I never through a code. When I start the car, and drive right away, the code gets thrown and I get the CEL. Its an easy fix.
Old Sep 5, 2008 | 06:47 AM
StangRalle's Avatar
You need a new tune to use the long tube headers without any error messages... Check with Brenspeed.
Old Sep 5, 2008 | 09:56 AM
Oneunderone, do you have a tune by Bamachips, Brenspeed, or someone else? If so, they can alter your current tune to compensate for the new o2 positions.
Ecostang
Nov 3, 2022 08:50 PM
ClayP
Aug 11, 2015 06:23 AM
Vader99
Jul 19, 2015 08:19 PM
Will3212
Jul 16, 2015 10:30 AM
