Check Engine light with Brenspeed 93 tune
Old Jan 27, 2008 | 07:58 AM
Rotormd's Avatar
Just yesterday I installed the C&L Street with the X3 Brenspeed 93 tune, took the car out drove it around every thing was working fine. but later I again took the car out and got a check engine light. I hooked up the X3 tool and it had one code "PO171 System too lean (Bank 1)". Do any of you guys have any advice? I had gone through two tanks of 93, before the install.
Old Jan 27, 2008 | 08:31 AM
rick06gtmustang's Avatar
call Brent
I would give Brent a call ASAP.Check for any kind of air leak as well.
Old Jan 27, 2008 | 10:48 AM
Louie's Avatar
Common slip-up possible: check the vacuum hose, is it connected?
Old Jan 27, 2008 | 11:02 AM
70MACH1OWNER's Avatar
My thoughts also. Double check all of your connections, hoses and clamps. Delete the code and go for another drive to see if it returns. If it does call Brent @ Brenspeed.
Scott
Old Jan 27, 2008 | 12:23 PM
Rotormd's Avatar
I checked and retightned the connections including the vac line everything seems OK, I cleared the check light and went out for a 15 min ride getting on it and everything, came back no check engine light. Then 20 min later I go to a friends house and the light comes back on
Old Jan 27, 2008 | 12:25 PM
ADudeInNewJersey's Avatar
Same problem with me but only it was Bama's tune that did it for me... A lot of ppl told me it was the O2 sensors... I haven't had time to check it out but it could be that too.... Good luck
-John
Old Jan 27, 2008 | 01:06 PM
JonW's Avatar
Have the O2 sensors been turned off as part of the tune?
Old Jan 27, 2008 | 01:19 PM
Rotormd's Avatar
Brenspeed put a sticker on the outside of the X3 pack that has (the rear O2 "ON" ) check marked. So I take that as, it is on.
Old Jan 27, 2008 | 02:01 PM
metroplex's Avatar
It sounds like the air transfer function might be off. Did the tuner program the tune for the correct CAI kit?
Old Jan 28, 2008 | 02:57 AM
STANG_IT's Avatar
Yup, sounds like you have to disable your o2 sensors on your Xcal or have Brenspeed email you an updated tune with them off.
Old Jan 28, 2008 | 07:52 AM
jmanpatsfan's Avatar
Brenspeed sells the X3 now?
Mackitude
Aug 13, 2015 01:05 PM
ClayP
Aug 11, 2015 06:23 AM
Ecoboost
Jul 25, 2015 06:32 PM
Will3212
Jul 16, 2015 10:30 AM
